#31
The H1 an H2 socket pins are what supply the CRT heater voltage to the pic tube.
Other than that one pin and a couple of the resistors associated with it, it doesn't look to bad! Also, it looks like that chassis should pull right out.The wire harnesses should be all plug ins but i could be wrong watch that 2nd anode cap as well as your going to have to discharge it before removal...
"IPC 610 Class E & J STD-001 Certified" |
