Old 06-01-2012, 02:57 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
You might get a spider or two. All depends on what condition the place was in that you got it from. It's always best to check it out before you put into your car or truck. After you get it home, use an air gun(if you have one) to blow all the loose bits and cobwebs out. Be careful if it was in a garage or storage area. be sure to check under the set for black widows or other nasty creatures. Wear gloves if possible. If it was inside and the home looks clean, probably not much to worry about. I've never had an issue but there is always a first.
