#35
I don't have much or any experience with RCA's CTC121 TV, but from what I have read here it was a very good set in its day, and it can be again. Unless the TV has been struck by lightning or some other situation that damages the set beyond repair, I'd at least try to find a used flyback. There are ways to silence noisy flyback transformers (if the fly is not squealing because of electrical problems such as shorts, et al.) as well. I remember reading in several old TV repair books of the '60s and '70s of a method that was nearly 100 percent effective as far as silencing squealing and otherwise noisy flybacks, but unfortunately it's been so long since I read of it that I don't remember the details any longer. One thing that does come to mind, however, is to drive little wooden shims in between the flyback coils and the core; this has been known to stop the squealing, at least until a new fly can be obtained. Are you sure it is the flyback that is actually squealing? High-pitched squealing noises in a TV set can also be caused by the horizontal oscillator running far off frequency, but not far enough off to kill the raster. Many people (myself included) cannot hear a CRT TV's horizontal oscillator in operation (15.75 kHz is just beyond the top end of the normal hearing range), but people from teenagers to those in their 20s and 30s often can, and they find it extremely annoying. I don't know how old you are, but you may fall into the 20-30 age bracket; if so, your hearing is probably sharp as a tack, extending even slightly above 15.75 kHz, and you are hearing the noise very clearly. But I digress. My point is that there are ways to silence noisy flybacks, as I described above; trashing a TV that may otherwise be working perfectly well, simply because the flyback is making noise, makes no sense to me whatsoever. I have seen many CRT TVs on trash piles (I've rescued a few, and at one point in the early '70s my basement in my former home was half-full of old sets) that needed only new tubes or a small part to restore them to normal operation. Even today's flat-screen sets can be repaired if one cares to go to the trouble to do so (and has the skills), but the way these TVs are built, with surface-mount components, the LCD/plasma panel itself often hard-wired to the chassis, and so on, most repair shops won't touch them unless the set is under warranty, and of course DIY user servicing of these sets is out of the question.
