Old 06-22-2011, 01:55 PM
Can anyone tell me if this Flyback will substitute ?
I have a Zenith mayflower chassis 28F22 , the fly inside the set is number S17669 , the sams says it is supposed to be zenith part number S15015 , it was probably put in there because the original was dead , i'd like to know if anyone can tell me if that S17669 can sub or is this someones hope to get the set running again?
Thanks
Mike
Old 06-23-2011, 11:01 PM
I have a very comprehensive Thordarson book and it confirms the S15015. (some versions apparently used an S-15709 but the details are vague) I cannot find a mention of the S17669 anywhere but it would have been from the era of the 22H20/22 chassis, something like that. I can't say whether or not it will work, but I would guess not. I have a Mayflower and it has one of the ugliest flybacks I've seen, but thankfully it still works fine. Maybe I can move it enough to read the number on it.
Old 06-24-2011, 09:53 AM
John Folsom's Avatar
I agree with Bryan. The S15015 crosses to a Fly 53, but I can find no reference to the S17669 number in any of my cross refs (Thordarson, Stancor, RAM, Merit). Are you sure about that number?
John Folsom
Old 06-24-2011, 10:26 AM
The only way i could be off is if one of the 6 numbers is an 8 , i measured the restiance and thats right , as far as functioning it was put in the set sometime ago so perhaps it does work or will work , i thought maybe someone would have the info on the two and i'd have the answer ... thanks for the help so far guys
mike
Old 06-24-2011, 11:43 AM
John Marinello's Avatar
<-- "Byron"
Here ya go.
Old 06-24-2011, 11:46 AM
Wow! One size fits all! Wonder why S17669 does not show in the xrefs?
John Folsom
Old 06-24-2011, 09:58 PM
I wonder if it is a supercession number, perhaps an improved version that Zenith offered for replacement in later years? I checked mine and it uses the S15015.
Old 06-24-2011, 11:55 PM
John
thank you so much , this does indeed help others for future porthole fly problems , thanks to everyone else too , now to figure out what is wrong with the set , fly tests good and this confirms the fly is useable
mike
