Old 05-21-2011, 12:22 AM
I've started working on the cabinet. First, I removed the screen bezel and speaker.
The green foam was stubborn in a few spots, but I got it off eventually with the help or a razor blade.
The feet had seen better days so I glued and clamped them.
Now how to deal with those bug holes ?
I did some experimenting with products available locally and settled on this Elmers wood filler. This cabinet is brown mahogany and the Elmers mahogany was a bit too red. I found that a blend of 2 parts mahogany, 1 part walnut looked OK once stained.
I did a little stripping test before filling in the holes and discovered the stipper sludge not only gets in the holes but discolors them too. So I'm filling them in first.
After filling in the holes, I've been scrapping off the excess with a single edge razor blade. A lot of the finish is coming off in the process so I think I won't need much stripper after all.
After staining and grain filling, I might also use some Mohawk brown Mahogany toner I have on hand. Toner lacquer works pretty well for hiding repairs.
Mahogany gel stain test with several blends of wood filler.
It's about as much fun as it looks
