the contrast is somewhat lacking, checked AGC, subbed a new video amp tube with a NOS, not much better. I have not checked but suspect a weak bypass cap in the video amp circuit.
ah I see another stage of video amp ahead of the 12BY7. Think I will give it a try. I also have to recheck the kine bias and make sure I have that set right. One last thing is there is a video peak switch I think I will play with. All the slide switches on the back seem a bit iffy, prob should give them a shot of clean juice.
3rd pic IF tube (6jc6) had a short, new one resulted less ringing look to the pic. its getting good enough for a screen pic, will post one soon. Checked the HV right on 25kv and very well regulated. I need to go back and check the HOT and shunt tube currents. The 6fq7 horz osc tube tested pretty weak but seems to be working ok. I will swap it out after I get the HOT current check setup to see how much difference there is with a stronger tube.
The tuner needs the normal cleaning but not going to get into it now. Overall this one has been pretty much trouble free. |
ARGH, I went out to get a pic, turn on set, GREEN only. I looke around and feel a power resistor near the R/B amp, stone cold, and I notice a brown wire that looks real bad, sure enough its broken loose. No way I can fix it with out pulling the chassis, so I will just make a note and put it away for now.
back in business, managed to get a jumper in there. I bet this was the problem all along (not the amp tubes but the wire, prob just got bumped when subbing out the 6gu7). done for now
that contrast is maxed out, tried the AGC adj for max contrast (just before losing sync). I am assuming its a gain issue somewhere as on my other sets too much contrast is easy to get. I still suspect the bypass cap in the video amp, but its not going ot be easy to get at so will have to wait. I just wanted something easy to work on and see if I could get it going quickly.
