sencore ps148 scope
Anyone familar with this scope? Just picked one up, nice working condition with the probes. The unit has 2 multi section can ecaps in it, and a few carboard style ones, which I'm going to replace.
Is this a decent scope to use on older radio's and early tv's? |
I don't know Sencore stuff but I had little respect for the company. They seemed to cater to the short-cut, low intellect kind of repairman (I won't say technician). Maybe it was just the way their stuff was presented.
Having said that, I imagine their stuff worked and if you have a 'scope it might be worth refurbishing. How old is it? I'd lean toward not fixing anything that ain't broke. |
not sure on the age, no copyright date in the manual. says it's a 5 inch scope and vectorscope. Probes came with it, and the original box.
I agree. Actually much (if not all) of the older B&K test equipment was made in Japan by Trio, also known as Kenwood.
B&K CRT checkers were our staple - the 440, the 467 and the 470 (favorite, by far). B&K scopes were rebadged Kenwood/Trio and Kikusui, not bad for the value, but their sub-15 MHz bandwidth stuff is junk. As for the OP's scope, it's probably a 5 MHz bandwidth scope, pretty easy to use and maintain. Cheers,
