Old 11-15-2010, 01:58 PM
mbear2k mbear2k is offline
Sencore Super Mack CR31A Manual
Does anyone have or know where I can get a manual for a Sencore Super Mack CR31A? I have the tube data book that came with it; just need the ops manual.
Thanks!
Old 11-16-2010, 12:14 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I think you can still get a copy of the manual from Sencore. I got one for my CR70 from them.
Ebay is probably a less expensive option. The manual doesn't fit well in the unit so I think they tend to get separated from the unit when they're sold.
John
Old 11-16-2010, 12:26 AM
ctc17 ctc17 is offline
I have one for my super mack. Is there anything specific you want to know? I have tested 100s of tubes with mine and know it very well.
Old 11-16-2010, 12:00 PM
John - I did call them and they do not have them anymore... nice folks, but no older manuals.
CTC - thanks for the offer. I've used quite a few different CRT testers/rejuvinators and understand the basics. I wanted to test a 10BP4 and am using socket 1.
- I set the filament voltage (6.3) and bias to "C".
- Gun balance set to R/B&W
- I set the FIL SET to align with 6.3
- Run through H-K Shorts and G Shorts (no meter movement)
- Select GUN BAL and attempt to adjust to mark on meter - I get no movement of meter
- I select EMISSION and get almost no deflection - but can get movement if I changes the GUN BAL control
And general questions:
- What does Automatic tracking do in Tester mode?
- If the tube does not have shorts and is low on emissions, do I start with Auto Cycle in Restore or Rejuv first?
Thanks!
M
Old 11-19-2010, 04:45 PM
jeyurkon's Avatar
Automatic tracking is for testing color CRTs. It stores the emissions on capacitors for each gun and comes up with a good or bad indication for tracking by comparing those at the end.
This is from memory so I might have it a little off.
John
Old 11-22-2010, 12:08 PM
jeyurkon's Avatar
I'm still trying to figure out where the heck I put my Super Mack manual, otherwise I'd copy it for you.
John
Old 11-22-2010, 04:18 PM
Thanks John - if you run across it! Much appreciated. If you do that, I will host it somewhere so others have access in the future.
M
Old 11-22-2010, 08:51 PM
jeyurkon's Avatar
After looking for the 20th time in the spot where I was sure I put it, it finally reappeared. There are 40+ pages. I'll try to scan it tomorrow.
John
Old 11-23-2010, 11:41 AM
jeyurkon's Avatar
Here's the manual.
** Now hosted by mbear2k ** CR31A
John
Last edited by jeyurkon; 11-27-2010 at 09:02 PM. Reason: Location of manual changed
Old 11-24-2010, 08:13 AM
John - thank you very much! I will get this posted also within a day or so and update this thread with the location.
Old 11-24-2010, 04:03 PM
Sencore CR31A Super Mack User Manual (permanent) Link:
http://www.oldtubes.net/library/test...r31a/CR31A.pdf
Old 01-31-2011, 10:05 AM
IsthmusTV's Avatar
Greetings,
I'm new to the vintage TV restoration world, although I've been restoring radios for decades. I'm at the point where I need a CRT tester. I have the opportunity to buy a CR-31A in excellent condition with all adapters, probes and manual for $50. Is this a good price? Any caveats with this model?
Thanks,
Clark
