Leave the fuse removed using the light bulb AS the fuse. That way the bulb tells you the level of short and you dont blow fuses over and over testing.
The output transistors that drive the speakers are on the heatsinks. The big ones below look like the drives and the small little plug in ones are predrivers.
This uses driver transformers between the driver and output, so it makes it fairly tough for a problem in the driver or before circuit to fry the outputs. If it turns out the drivers are shorted, it could very well be a leaky cap if caps are used to isolate the output transistors from the speakers.
Start by pulling the big transistors out one at a time, measure between the two pins then between the case and each pin using the lowest ohm scale setting. If one is shorted it will read close to 0 ohms.
The other way is the check it with diode test on the meter. A reading of .500 volts is common in some directions but none should read 0 or shorted.
