Old 11-07-2010, 02:25 PM
j4570 j4570 is offline
VK Member
Series Power Supplies?
I need 90 VDC to test an old battery radio.
Can I hook up a couple of triple power supplies (each is 5V/20V/20V and can be added together for 45V, then I need two of them) to get 90 VDC? Or is there some ground problem/issue I am not aware of?
I'll post over in videokarma too, since this is for an old radio.
Old 11-07-2010, 02:49 PM
It depends on the power supply. If the outputs are floating (negative terminals are not tied together internally), it should be fine. I use an HP 6228B dual 0-50V connected in series to get 90 volts.
Old 11-07-2010, 03:31 PM
VK Member
I can do the supply itself.
What about using two seperate supplies??
Jason
Old 11-07-2010, 04:45 PM
Again it depends on the supply. If the negative terminal is connected to either the neutral or ground on the AC plug, it won't work.
perhaps you could just build a 90 volt supply from scratch ? Here's a very simple transformerless circuit http://www.antiqueradio.org/bsupply.htm
Old 11-07-2010, 06:29 PM
VK Member
I ran across that page a while back, forgot about it. I might do that if I don't do somehting else. The radio I have only needs 1.5V and 90V. I guess I could always go the 10 9V route.
I want to see if this works before I construct a permanent supply for it.
I'll look on E-bay for a bigger supply, always a good excuse........
Jason
Old 11-08-2010, 03:18 PM
Reece's Avatar
Reece Reece is offline
You could go to the dollar store and buy ten cheap 9-volt transistor batteries and snap them together + to - and get 90 volts for your test. You might be surprised how long they would last, too. If you need intermediate voltages just capture a wire between snapped terminals at the appropriate point between batteries. Ditto for your 1.5 volt supply: put a couple of D cells in parallel for more amp-hours.
Reece
Old 11-08-2010, 06:30 PM
VK Member
I was under the impression that the 9V's wouldn't last that long. Looks like from some basic informaiton, Alkalines would last at least 10 hours.
If I had enough AA battery holders (I used to have tons for old CB's, 8 each for 12 Volt, probably tossed them), I could get close with AA rechargeables I bet. Well at least 1/2 there.
Jason
Old 11-11-2010, 08:27 PM
Findm-Keepm's Avatar
Followin' the Rules...
http://home.comcast.net/~morrised200...structions.pdf
Simple!
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
