Old 05-18-2010, 10:11 PM
holmesuser01's Avatar
Originally Posted by Tubejunke View Post
The original tubes likely have dirty pins. As the heat expands the metal socket connections they become intermittent and touching them makes them act up. I always take an old pocket knife and scrape the often invisible film from all tube pins, then I spray the socket with cleaner and repeatedly insert the tube for a scrubbing action.
Also, that blue glow that you mention in the CRT neck may be a bit of gas, but that doesen't necessarily mean that the tube is bad.
I know what you're saying about the tuner tubes. When I got the set, I wasn't planning to actually TAKE the set... just rob the tubes and speakers. I went so far as to pull all the tubes, including the 1B3.
Then, it hit me. I wasn't going to let that happen. Went back and collected the set. The original owners son was happy. He didnt want to see it die that way. I cleaned all the tube pins before I reinstalled them.
The set sat on my covered porch for a month until I could make space in the house. It's facing the wall these days.
The Micromatic turntable will be the subject of another topic elsewhere as soon as I can get my camera back in my hands.
The pic shown is on the porch, the day after I aquired the set. It was 32 degrees and windy with all that sunshine. OEM kine being tested at 7 volts when it heater decided that it had enough.
