Old 05-13-2010, 07:41 PM
Originally Posted by zenithfan1 View Post
The Blonder Tongue modulators and similar types have an output of around 60dB, turn the gain all the way up and hook it to an antenna instead of cable, and bam, instant transmitter. I get a block radius with it transmitting from a pair of rabbit ears.
I'd watch that if I were you. Since your setup gives you a range of a city block, your modulator is now in effect an unlicensed television transmitter, which the FCC frowns upon--so please don't continue this experiment too much longer. The modulator will operate fully within the letter of the law, however, if you connect the output to a cable which is then connected to the antenna input of a TV set. I am a licensed amateur radio operator (WB8NHV, since 1972) and feel I know the FCC's rules regarding unlicensed operation, among others (especially Part 97 which governs amateur radio), fairly well, so I'm not giving you a hard time--just informing you of something you may not be aware of.
