I did cringe in fact when I read your remarks about the English. If there is one parallel I can draw between English and American culture, it is a tendency for both cultures to be rather self-depreciating until the point that all pride has been lost, it becomes a national malaise and then becomes true. I suppose this is the opposite of German arrogance that often goeth before the fall. (Brits, feel free to tell me if I'm off-base) History lesson on the aforementioned British jet aircraft... There were two schools of thought with regard to increasing the thrust of jet aircraft in the waning days of WWII. The British (Whittle) design used a better-understood centrifugal-flow compressor. The main drawback was the need for ever-increasing frontal area for increased thrust. The Germans (von Ohain) used an axial-flow compressor. While it didn't require the increased frontal area, it did require metallurgy skills beyond what was available in the WWII era, and was thus quite fragile. It could also not offer the same resistance to "flame-outs" as the British unit, and many crashed under severe maneuvers (or were shot down by slower, yet more maneuverable piston-engined aircraft). The upshot of this is that in 2010, English WWII-era jets continue to fly using their original jet engines, while all of the early German jets that are still air-worthy have been retrofitted with modern, American jet engines. Yet in the minds of most without this technical perspective, it is the WWII-era Germans who are most associated with successful jet engine designs. There is that self-depreciation at work. And as a more recent example... As a proving grounds mechanic in 2003, I had the pleasure of off-road testing a fleet of four Mercedes ML 320 SUVs against the then-current Jeep Grand Cherokee. Within two weeks of 24/7 testing, all the Mercedes had burned through their budget of replacement parts (including entire engines) while the Jeeps happily bounced along without a single failure. In the end, the Benz's were restricted to the same torture-testing as the most flexible vehicle in the entire Chrysler line-up, the Sebring Convertible because this was the only route the MBs would cover without suspension and driveline failures. Yet in the ignorant mind of the mass-media, I continually see the 2011 Jeep GC referred to a "based off the new Mercedes", when in fact the opposite is true. Since this falsehood is considered advantageous to Jeep sales, no one publicly refutes the fact and I have to listen to "experts" (who are simply good at reading newspapers) tell me how the new Jeep owes everything to the Mercedes engineers... ![]() I guess the point is, unless you're skilled in a particular field, it's best to realize that opinions are just that.. Opinions. Please don't take this personally, I intend no harm, only clarification.
From Captain Video, 1/4/2007 "It seems that Italian people are very prone to preserve antique stuff." Last edited by Carmine; 01-08-2010 at 10:08 AM. |
