Old 12-09-2009, 03:27 PM
crtfool's Avatar
crtfool crtfool is offline
Originally Posted by YamahaFreak View Post
This is not encouraging. I needed to use water because the coolant was everywhere, and probably would have been near impossible to completely remove otherwise. I'm not sure where the smoke came from, but I will take a closer look tomorrow. It seemed to emanate from the general vicinity of the audio amplifier. Hopefully, it's something simple(capacitor, resistor, etc.).
Does anyone know of a place where I might find schematics for this set?
P.S.--Is that a CRT from a video camcorder viewfinder in your avatar?
Yes - that is a 1/2 inch B&W CRT from a camcorder. I collect mini TV sets and micro CRTs and EVF units. I would love a 1/2 inch COLOR CRT, but the smallest ever made was 1.5 inches.
BTW - I was not chastising anyone for suggesting using water on circuit boards, but I have seen what damage water can do, especially to solder joints, and I would never use it - I would use isopropyl alcohol instead in an emergency situation because it evaporates very quickly.
At the very least, you will get some very good experience working on a set that you got for free - and if you do get it working properly, it will give you lots of satisfaction. Again, just be careful - regular CRT sets have lots of very high voltage in and around the CRT, but these projection sets have triple the amount.
