I know that others have said that using water on electronic circuitry is not harmful, but I would never have done that on purpose - there are circuit board cleaning and degreasing sprays that are non-conductive and they evaporate very quickly so that they can be sprayed on live powered circuitry with no danger or damage at all. Since you did use water, it would have been a good idea to let them dry completely for a few days before trying to power them up.
Unfortunately, you let the smoke out of at least 1 or more components - and even though nothing looks burnt, they are damaged and will no longer work properly, or even within critical safety specifications. On all manufacturer service documentation, and even third party service manuals, critical safety components are usually identified as such with at least an exclamation point symbol. If you do attempt to continue troubleshooting this set, PLEASE proceed with extreme caution from this point on. |
Does anyone know of a place where I might find schematics for this set? ![]() P.S.--Is that a CRT from a video camcorder viewfinder in your avatar?
Sony Trinitron Fan |
The MSDS for the replacement coolant says that it is about 75% ethylene glycol and 25% glycerine. I'm not sure there's much besides water that would have worked.
While letting it dry longer might have been prudent, any damage done probably occurred when you turned the set on right after the leak. You could try partsrruss.com for the service info or use google with the the model number and "service manual" as the keywords. John |
![]() andy, I'm still hoping that if I let it dry for a few more days, I'll get somewhere. If not, it's looking more and more like the scrap heap for this set.
If you're lucky, the smoke came from a wet power resister, or another component that normally operates hot. I wash stuff regular with heavily-deluted dish soap, or Windex, but it has to be bone-dry before power is applied. I had to replace contaminated coolant in a Phillips set years ago.
Blue also. That was back when a local TV shop sold the coolant over the counter. They told me that the blue was the first to fail, and the theory was that the blue CRT assembly area was closest to the cabinet assembly area. Hence, more dust & contaminants in the air. Freak accident years ago... A full can of beer was batted off of a counter, and landed upside-down inside of a computer, while the computer was in use. You had to see it to believe it. What a shot! Entire mother board & every card in the expansion slots was frothing like a rabid dog. I immediately unplugged it and sprayed everything down in the kitchen sink. I blew as much water out that I could, put it on the heating register, covered it with a blanket, and let it sit for a few hours. The clock lost 15 minutes, but otherwise it worked fine. |
I think that you might be right about the smoke, as it never really smelled. I'm letting the board dry for a few days; should I put it in the sun?
BTW - I was not chastising anyone for suggesting using water on circuit boards, but I have seen what damage water can do, especially to solder joints, and I would never use it - I would use isopropyl alcohol instead in an emergency situation because it evaporates very quickly. At the very least, you will get some very good experience working on a set that you got for free - and if you do get it working properly, it will give you lots of satisfaction. Again, just be careful - regular CRT sets have lots of very high voltage in and around the CRT, but these projection sets have triple the amount. |
