Old 12-07-2009, 05:25 PM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
Good learning experience here. It's be a miracle if you get it going again. Keep us posted!
Old 12-07-2009, 06:26 PM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
I was dreading that phrase. Well, it's DUMPING rain here right now, so there's no way I can get into the set now. (don't worry, it's covered!) I really hope I can get it working again...)
Sony Trinitron Fan
Old 12-08-2009, 01:11 PM
rcaman's Avatar
rcaman rcaman is offline
we use windex and water it works 100% of the time in getting coolant off. then use a heat gun or hair dryer on the board.........
Old 12-08-2009, 03:58 PM
Just spray the board down with Windex, let it sit for a few seconds, and hit it with the water?
Sony Trinitron Fan
Old 12-08-2009, 07:08 PM
Post Update
I removed the board today and sprayed the entire thing down with the 'mist' setting on my garden hose. I covered the openings on the flyback and HV distributor so as not to let moisture in. Then I used a combination of a hair dryer and leaf blower to dry the board thoroughly(hair dryer wasn't moving enough air!). Thank God they numbered all of those zillions of wires connecting to the board, by the way.
So it's all back together. Now I try it again. When I hit the power button for the first time, the flyback (I think) makes a buzzing like a bug stuck in a zapper, so I unplug the set. I also notice a good amount of smoke coming from behind a side panel that I can't tell what's on the other side of. I remove said panel and thankfully can't find anything charred or smelly. So I try it again. (bad idea?) This time I hear a low-pitched whine for about a second, then the flyback tries to start up but cuts off within a quarter second. No smoke at all this time. I try this several more times always with the same result. My guess is that there is some moisture inside the flyback that is causing a short, which in turn is causing the power supply to shut itself off to prevent damage. Do you think that if I give it some time, the moisture in the flyback will evaporate and I might get better results?
Sony Trinitron Fan
