Old 05-27-2009, 09:00 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
The transformer would be useful if there was a heater to cathode short. I believe edison64 said that the cathode is open, in which case the transformer doesn't help.
Checking the solder connection at the base would be the first step.
If that's not the problem and there is absolutely no emission even with raised heater voltage, then it could be an open cathode. Then it might be worth trying to weld the cathode. Some CRT testers such as the Sencore CR31A can be used to attempt to re-weld the cathode.
John
