http://www.mindspring.com/~laserguru/digitalage.html http://www.moesrealm.com/hometheater...isc-guide.html If you want cheap but good, you can often get one of the players "Moe" calls "average" quite inexpensively. They are much better than most of the older players, yet they often cost next to nothing to buy. My first laserdisc player was an old Sony (I don't remember the model number). I replaced it with a Pioneer CLD-D505, which was a vast improvement in picture quality. I later upgraded to a Pioneer Elite CLD-79 (but still have the CLD-D505 for backup). I believe that there are only two Pioneer players made for the U.S. market that are better than my CLD-79 (though they did make better models for the Japanese market). The difference between my two Pioneer players is not dramatic, unlike the difference between my lessor Pioneer and the old Sony it replaced. Basically, any Pioneer made with an AC-3 output that will play both sides without you flipping it over, if functioning properly, will give a decent picture, though some are better than others. (The reason I say, "with an AC-3 output that will play both sides without you flipping it over", is not because that output and feature will help with the picture, but because that way one will not be getting a very old player or a very low end model.) If you want greater precision for advice, look to the links above. With laserdisc players, since the picture is analog, like other analog devices, the player makes a significant difference in the quality of the output. The differences between different DVD players, though real, are generally much less than the differences between different LD players. Really, though, if you are planning on buying a laserdisc player you should go to the links above and read each of those two web pages thoroughly. You should also ask yourself why you are getting a laserdisc player, as most people would be well advised to stay away from it, as the picture is not as good as DVD, and the sound format options are the same (excepting only the original, inferior analog sound). [Of course, just because the format options are the same, that does not mean the makers of the DVDs used all of the options, as it is much more common to have 2 channel PCM on a laserdisc than it is on a DVD, though it is on some DVDs. The downside to 2 channel PCM for soundtracks is that that means that the center and surround in a film will be matrixed via DPL, instead of being discrete DD 5.1.] The reason I use a laserdisc player is because of the fact that there are films, and versions of films, that never made it onto DVD, so this is the best consumer product to see those films. But if they were all on DVD, I would go with DVDs because the format is capable of a better picture, and because there are not side change breaks every hour like a laserdisc. Naturally, anyone who has had a laserdisc player since the late 1970's might have a substantial LD collection, and for such a person, it would be quite expensive to replace all of the discs with new DVDs, even if all of them were available. Such a person might want to pick up a good laserdisc player instead, unless they already have a couple of them. As for S-Video versus composite video, read the links above, as they give excellent advice on that subject. Before I replaced my TV last year, I was better off using the S-Video output of my CLD-79, but with the new TV, I am better off using the composite. Evidently, my CLD-79 has a better comb filter than my old TV, and my new TV has a better comb filter than the CLD-79. |
