Old 01-21-2009, 11:54 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
You're forgetting about Extended Definition Beta which went a step beyond S-VHS with 500 lines of resolution. .
Didn't forget just didn't mention it.
I always preferred the mechanical design of Beta VCRs (particularly Sony). They were harder to work on if you didn't know what you were doing, but most good things are like that. I never saw a serious mechanical problem that wasn't caused by a botched repair, or alignment attempt. My own personal Betas have been very reliable. Sony figured out how to FF and Rew with the tape threaded from the first Beta, but it took VHS until the late 80's.
I always blamed the full loaded rewind on the reason so many Beta machines came in with worn out heads and worn out cylinders. I think some of the Sanyo Beta machines would unload the tape from around the cylinder in Rewind. And when I saw VHS machines leaving the tape loaded around the heads for faster control response, I cringed. I preferred unloading the tape from around the cylinder for FF and Rew. The half-load arm that some VHS have that lets the CTL track be used as a real time counter worked pretty well and didn't contribute to head wear. I like that idea best.
I remember when the SL-2500 Sony's first front-loader came out and they were breaking the guide pins off the loading ring left and right, a major repair, along with the FL shaft plastic gears. And the SL-5400 generation with their seizing capstan motors. We were both Zenith and Sony authorized service and were running sometimes 2-3 weeks turnaround from the backlog of Beta machines!
