Old 11-05-2008, 10:36 PM
MRX37 MRX37 is offline
Originally Posted by jpdylon View Post
if when you plug it in and all it does is whine, the switching power supply may be at fault.
Don't waste your time with it. The parts will cost you more than the set cost to build!
I have several chassis boards with good power supplies, so if I can use parts from them, that won't cost me anything. If it's bad caps, I can sure as hell replace those.
Assuming I already have the parts, would this be an easy fix? If not, then I'll shit can the TV.
