-   Rectangular Screen Tube Televisions (http://www.videokarma.org/forumdisplay.php?f=45)
-   -   Funai!!! (http://www.videokarma.org/showthread.php?t=191859)
MRX37 11-05-2008 08:59 PM
Funai!!!
I found a nice looking 19 inch TV/VCR combo. It's a Symphonic model# SSC199V. I plugged it in only to hear a high pitched whine, and nothing else. Wouldn't power up, wouldn't do anything.
I looked on the back and found something pretty scary: "Distributed by FUNAI CORPORATION..." I took the back off, and the CRT was also made by Funai...
Should I even bother trying to fix this?
zenith2134 11-05-2008 09:08 PM
Bad flyback. I wouldn't even try to fix it. I have a personal vendetta against Funai! :D:yes:
MRX37 11-05-2008 10:01 PM
Is there a way to test the flyback? Say with a multimeter?
jpdylon 11-05-2008 10:12 PM
if when you plug it in and all it does is whine, the switching power supply may be at fault.
Don't waste your time with it. The parts will cost you more than the set cost to build! :lmao:
zenith2134 11-05-2008 10:15 PM
That's true. I sugested that it might be the flyback since I've come across more than a few Funai-built sets (Symphonic, etc) that had toasted flybacks. And if it's bad chances are there are some other parts that are also shot sch as the hot.
EDIT: to test the flyback i'd find a flyback ringer or somehow drive the horizontal or even the transformer alone to see if it's good.
MRX37 11-05-2008 10:36 PM
I have several chassis boards with good power supplies, so if I can use parts from them, that won't cost me anything. If it's bad caps, I can sure as hell replace those.
Assuming I already have the parts, would this be an easy fix? If not, then I'll shit can the TV.
zenith2134 11-05-2008 10:45 PM
Hey, by all means try it if you want to. If the fly is good the switching supply shouldn't be too involved to tackle. But again, the set isn't anything to write home about. And even the best TV/VCR combos have mediocre VCR transports and heads.
MRX37 11-05-2008 10:55 PM
Eh, I looked at some of the parts, including the TINY horizontal output transistor, and said "fuck it!"
I'm shitcanning the TV. Even if I did fix it, it'd come back to haunt me after I sold it.
radiotvnut 11-05-2008 11:10 PM
I'll bet that's one of those single board jobs with the VCR deck screwed on top of the chassis. In order to get to the underside of the chassis, you must remove the whole chassis out of this plastic housing. Is my description pretty accurate?
For future reference, when I encounter a switching power supply in a TV that squeals, the first things I check are the HOT and the diodes off the secondary side of the switching transformer. More times than not, one of these components will be shorted. There's also a zener diode that I've seen short in the newer Funai built TV/VCR combos and cause the P/S to squeal. I couldn't tell you if that was all that was wrong because I never could figure out the value of the diode and I $h!tcaned both TV's just out of spite.
These newer Funai TV/VCR combos are total crap to begin with. They are not designed to be repaired and the components are under rated and are of inferior quality. You'll also be interested to know that if the VCR mechanism fails, it will shut the TV down. I've "faked" a few into staying on; but, not many. That's just something else they do to make the set totally useless should the VCR portion fail. I too have a vandetta with Funai TV's. Their crap helped to put many service shops out of business.
I've got a 27" Funai set that came to me with a bad HOT. Replacement of the HOT revealed a bad flyback. I can get a flyback for around $20; but, why bother? The chassis will likely have other issues and even if I fix it, I'd have a hard time getting my money back.
wa2ise 11-06-2008 02:12 AM
Originally Posted by MRX37 (Post 2229750)
Eh, I looked at some of the parts, including the TINY horizontal output transistor, and said "f*ck it!"
I'm shjtcanning the TV.
This is the sort of thing I salvage the circuit board to add to my "junk box". Or just pull the more interesting parts, like high voltage caps and power resistors. Though I'd test them if they came out of a blown TV.
MRX37 11-06-2008 02:35 AM
Yep, it was anyway. Now it's just a chassis board added to my other junk boards. It might not even be there for long, as I don't trust Funai caps...
waltchan 11-06-2008 12:14 PM
Funai is looking with a strong future...
Despite all the bashings with Funai, Funai has definitely surprised me with their newest ratings by Consumer Reports. The highest-rating Blu-Ray HD disc player is not Sony, but Sylvania (what) :yes:. The most reliable LCD TV brand is not Panasonic, but Sylvania again (what) :yes:. I know, I know, but that's what Consumer Reports say. With what Funai is standing right now, I fear that Funai will be the most powerful OEM maker in the next coming years and will probably overtake Sony in terms of quality. After the ratings were published, I notice that the Sylvania Blu-Ray players are disappearing from store shelves fast.
zenith2134 11-06-2008 01:13 PM
Well, Mr. Waltchan. Funai may have cleaned up their act when it comes to flat panel sets and BD layers, but they couldn't build a CRT set to save their lives. I can't remember one CRT Funai that actually looked good and lasted more than a couple of years.
zenithfan1 11-06-2008 01:54 PM
ven-detta! VEN-DETTA!!! {Simpsons fans know what that is from}
Celt 11-06-2008 01:58 PM
I have a four year old Funai (Emerson) set that gets daily use in the bedroom. But it's a little 13" set and those are usually reliable no matter who makes them.
