Old 10-22-2008, 02:41 PM
Duane's Avatar
Duane Duane is offline
Forgot to mention.This Zenith probably does not have a menu system.A lot of older projectors used analog pots that you use to set up geometry for each tube.That's why it's important to be able to turn off all light from the tubes except the one you are sizing.You always start with the green gun first and then the other two.Once you have them equal, then you go thru the convergence steps. There will usually be pots for each color and they will have name like hpos,vpos,hsiz,vsiz,skew,bow,lin,etc. See if you can find these anywhere.Typical place for them would be in the rear of the set with the cover removed.They should be all bunched together..so, you may see ghpos,rhpos,bhpos or something like that which would refer to green,red and blue horizontal position..Vpos would be the vertical pos and so on.
