Old 08-04-2004, 06:02 PM
H2s04's Avatar
H2s04 H2s04 is offline
auralmicitisis
Exclamation Worlds most filthy tube contest!
A 1X2B snatched out of what I believe was an old GE set.
Anyone else have a tube as ghastly as mine? Bring it on
.//H2S04
the gallery
Old 08-04-2004, 06:27 PM
Damn, son, that nasty thaing looks like its got tobacco juice & shite on it. Howdja get it out? Hope you used a tube puller. I sure as hell woudn't wanna touch it. -Sandy G.
Old 08-04-2004, 10:25 PM
glen65's Avatar
glen65 glen65 is offline
Member
Well at least you don't need to bother
to put it on a tube tester.
Old 08-04-2004, 10:41 PM
RuSsMaN's Avatar
RuSsMaN RuSsMaN is offline
Pudknocker
Jeff, you didn't even give us a chance.
I don't know if that one is toppable, period.
Cheers,
Russ
Old 08-04-2004, 11:20 PM
H2s04's Avatar
auralmicitisis
Russman & Sandy G: I have absolutely no idea how this tube got so damn dirty. The chassis and other tubes in the set weren't all that bad anyway. My guess is that when the set was manufactured, the HV assembly was coated with some sort of resin, that now, has aged, and was probably affected by X-rays and heat emitted by the tube itself. I added the rotten wood dust as a decorative accent
Glen56: I dont think this'll get any use in the future, but it will get a special spot in the work room
.//H2S04
the gallery
Old 08-04-2004, 11:33 PM
Dirty on the inside
This ones filthy on the inside, came out of Philco 1105 TV. Apparently overloaded at one time!
Old 08-05-2004, 06:30 AM
Chad Hauris's Avatar
That 1x2 looks like it was coated with wax that dripped from the flyback and then heated up due to tube heat. I was working on a RCA 8" 1950's portable, where flyback wax had dripped all over the H.O. and damper tubes...used some Goo Gone to remove it. The tubes worked fine.
Old 08-05-2004, 10:50 AM
captainmoody's Avatar
captainmoody captainmoody is offline
Eric, Was that a tube or flashcube?
Old 08-05-2004, 06:38 PM
It must have lit up like a flashcube, glad it happened prior to me getting the set.
I replaced it and the set came on and worked somewhat so it wasn't a shorted cap, or the short went away.
Old 08-17-2004, 10:49 PM
Tubejunke's Avatar
The 1x2B looks like an electric turd. Hey maybe an idea for a band!!
Old 08-17-2004, 10:57 PM
"Electric Turd". Hmmmm-Does sound like some obscure punk band from around 1980 or so....-Sandy G.
Old 08-18-2004, 02:02 AM
kby's Avatar
kby kby is offline
AK Member
Wink You could just drop it in your moniker...
...although it won't do much if it's wax.-kby
