-   Rectangular Screen Tube Televisions (http://www.videokarma.org/forumdisplay.php?f=45)
-   -   Worlds most filthy tube contest! (http://www.videokarma.org/showthread.php?t=22464)
H2s04 08-04-2004 06:02 PM
1 Attachment(s)
A 1X2B snatched out of what I believe was an old GE set.
Anyone else have a tube as ghastly as mine? Bring it on :p:
Sandy G 08-04-2004 06:27 PM
Damn, son, that nasty thaing looks like its got tobacco juice & shite on it. Howdja get it out? Hope you used a tube puller. I sure as hell woudn't wanna touch it. -Sandy G.
glen65 08-04-2004 10:25 PM
Well at least you don't need to bother
to put it on a tube tester.
RuSsMaN 08-04-2004 10:41 PM
Jeff, you didn't even give us a chance.
I don't know if that one is toppable, period.
Cheers,
Russ
H2s04 08-04-2004 11:20 PM
Russman & Sandy G: I have absolutely no idea how this tube got so damn dirty. The chassis and other tubes in the set weren't all that bad anyway. My guess is that when the set was manufactured, the HV assembly was coated with some sort of resin, that now, has aged, and was probably affected by X-rays and heat emitted by the tube itself. I added the rotten wood dust as a decorative accent :puke:
Glen56: I dont think this'll get any use in the future, but it will get a special spot in the work room :p:
Eric H 08-04-2004 11:33 PM
Dirty on the inside
1 Attachment(s)
This ones filthy on the inside, came out of Philco 1105 TV. Apparently overloaded at one time!
Chad Hauris 08-05-2004 06:30 AM
That 1x2 looks like it was coated with wax that dripped from the flyback and then heated up due to tube heat. I was working on a RCA 8" 1950's portable, where flyback wax had dripped all over the H.O. and damper tubes...used some Goo Gone to remove it. The tubes worked fine.
captainmoody 08-05-2004 10:50 AM
Eric, Was that a tube or flashcube?:p:
Eric H 08-05-2004 06:38 PM
It must have lit up like a flashcube, glad it happened prior to me getting the set.
I replaced it and the set came on and worked somewhat so it wasn't a shorted cap, or the short went away.
Tubejunke 08-17-2004 10:49 PM
The 1x2B looks like an electric turd. Hey maybe an idea for a band!!:puke:
Sandy G 08-17-2004 10:57 PM
"Electric Turd". Hmmmm-Does sound like some obscure punk band from around 1980 or so....-Sandy G.
kby 08-18-2004 02:02 AM
You could just drop it in your moniker...
...although it won't do much if it's wax.-kby
