Old 03-14-2008, 04:50 PM
Post
Who knows it might be a capacitor , I cannot get a reading off it at all with the VTVM , even at the RX1 meg setting
It's definately a cap, ceramic. These rarely fail. Odds are something else in the set has failed.
Old 03-14-2008, 05:08 PM
Old1625's Avatar
Old1625 Old1625 is offline
The component you pictured for us--where is it connected in the mess? If you could return the original component to its spot and take a pic of it and post it maybe I can figure things out. Armed with the tube # I can get the basing info and puzzle it out. If you can get a closeup (like 2-3 inches square enlarged to as large a frame as will show reasonably cleanly) and then another farther out (like 4-5 inches square--ditto the last) maybe I can see enough to troubleshoot.
I'm used to troubleshooting without schematics as a rule, as I've always been too cheap to buy them. Nowadays the WWW makes it easier to obtain such info for free, but not always.
A Hartley usually operates by working the plate with the grid through a center-tapped coil with the tap fed by B+, or working the grid with the cathode, with the tap connected to cathode and the low end of the coil to ground. Finding out where that stray component fits in the general scheme may help solve the riddle as to what it is, and help us all to solve this problem. Just my .02....
We may go through all this only to discover that the socket itself is bad...
Old 03-14-2008, 06:02 PM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
I used to work at a electronics parts store and that looks like an Inductor to me, according to this web page it is a 4,700 microhenry coil with a 10% tolerance, just my 2 cents, Logan
http://electronic.netsons.org/?q=node/61
Old 03-14-2008, 09:10 PM
The world of inductors/peaking coils, etc. seems to be full of black magic for those of us who can barely keep our caps and resistors straight! One issue is they come in a variety of shapes and sizes.
Old 03-14-2008, 11:59 PM
Old1625's Avatar
My take on the "coil" aspect of this is that most I've seen are bumped out at the middle like a dromedary camel rather than double as a bactrian.
But--all kidding aside--my feeling is we need to see a schematic for this apparatus, or perhaps the instructions I outlined in a previous post describing specific picture-taking would perhaps give us all some hints as to what's going on.
As I might have said I am used to the martyrdom of having to cypher out a lot of these engineering cluges without such aid. Laced-together wiring of such as Tektronix practises usually makes a schematic essential. But a lot of this other stuff is freer in physical wiring nature, leaving open and more apparent the actual hookup of one part to another.... Pictures of the scene of the crime would help--perhaps....
Old 03-15-2008, 12:15 AM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Does it look like current eBay item 160216976950 ?
Old 03-15-2008, 05:33 AM
Yep that's the same as it , I might buy that one too, Double my fun .
Old 03-15-2008, 07:26 PM
NowhereMan 1966's Avatar
NowhereMan 1966 NowhereMan 1966 is offline
Slave to 1 Cat
My friend went to tech school in the mid 1980's and he learned the resistor color code as: "Blacky Brown Raped Our Young Girls But Violent Gives Willingly - Get Some Now" where the "Get Some Now" is the code for the tolerances. I've also heard a much more un-PC version but this more "PC" version is more accurate anyways.
Mom (1938 - 2013) - RIP, I miss you
Spunky, (1999 - 2016) - RIP, pretty girl!
Rascal, (2007 - 2021) RIP, miss you very much
Old 03-15-2008, 08:33 PM
Old1625's Avatar
These are interesting and entertaining mnemonics for the RMA color codes!
But, since I started out in electronics experimenting at the tender age of 8, and going to the local public library to check out books on radio and electronics (you would never find me in the children's section--never went there! ), and thus dealing with these striped components, I wasn't exactly up on what rape was all about--nor anything else along those lines for that matter.
I'll be honest with you all: I never needed any aid to remembering the color code; I just learned it. At a very early age.
By the time I was almost 9 I could read a resistor and tell at a split-second glance what its value was. Don't ask me why... I guess that the younger one is the more quickly they learn...
Always--and to this day--my storage drawers of resistors are labeled in colors indicating the first and third bands of the banding of the resistor--rather than by numeric indication of ohmic value. Go figure. Do any of you do it this way....? I'm curious as to how many of us can glance at a resistor and without thinking about it can blurt out its value in an eyeblink....
