Its an exact duplicate of mine. Mine has served many hours with only a few hiccups. I'm actually pretty impressed by these little sets. Very reliable.
David |
Those were remarkable little sets for the time. But remember....
1) The dot pattern on the screen is of exactly the same density as for larger CRTs of the time. This means iffy resolution at best. 2) Some of the compactron tubes used in some sets of this vintage are made of pure unobtainium. It was in the early 1980s that I had one of those sets on my bench with a complete sync failure problem. After being on for about 5 minures the picture would suddenly start to spin and roll. Turned out that a triode section in one of the compactrons would develop a grid-to-cathode short after warm-up. After futile search for a replacement, and a customer that reeeeeaaallly wanted this set to survive, as he really liked the thing, I said I'll see what I can do. After some meditation over this matter I went out to my car and removed the battery, and brought it in to my bench.....Inside of 15 minutes I was buttoning up that set--fully functional, and with that tube working just fine.
http://pw2.netcom.com/%7Ewa2ise/radios/compaa3.html
Cool projects wa2ise!
I paid 50 for my portacolor, but I couldn't resist, the thing looks like it was in a time capsule |
I forget the CRT numbers, but the original CRT type that GE used for the first model-year Portacolors was indeed like that, but the later one used after the first model year was much better (if you put one of each side-by-side, the difference in dot pitch is really easy to see!). However, when GE switched the PortaColor from a dot-phosphor CRT to a stripe-phosphor CRT in the early 1970's, the resolution went right back down again.
The evolution of CRTs in that model of GE set is a interesting thing to know. Thanks! |
