Old 12-11-2007, 11:41 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
Originally Posted by Tubejunke View Post
I would be interested in the price and shipping cost of the 21ZP4A.
The 21ZP4A did not test good, are there any other numbers that will work? some of the tubes I listed had 4 other numbers on the box, I just listed the first
Old 12-11-2007, 11:49 PM
radio nut's Avatar
Originally Posted by compucat View Post
The metal RCA portable uses an 8DP4 rectangular tube. The 8BP4 is an 8" version of the 7JP4. I too would be interested in a price for that 8BP4 tube since I have a Motorola 9VT1.
Fair Radio has 2 used 8BP4's, one has surface scratches on the screen, the other is clean.I can check for price on wed.I have a new 8bp4. It was tested for 5 hours in a working set. I am a radio person by hobby, I do not know picture tube prices. If you want the new tube, Make me an offer.
Old 12-11-2007, 11:50 PM
David Roper's Avatar
console lover
a 5ABP1 will work fine if he likes green!
The 21AWP4 has no direct sub/crosses no other tube and of course I'm lucky enough to have a set with one that's weak. Another set of mine has a 20" rectangular tube that some clod ripped the base off of...IIRC the 20HP4 is a suitable replacement.
tvontheporch.com
Old 12-12-2007, 12:42 AM
radio nut's Avatar
Originally Posted by David Roper View Post
20HP4 is electrostatic focus, right? It and 21AWP4 are tubes I've been looking for.
I will test them and get prices as soon as I can
Old 12-12-2007, 12:56 AM
radio nut's Avatar
How did your set catch fire? Was it the ballast tube? Mine always ran hot around the ballast tube. The ballast tube burned out and that is why my otherwise restored set is temporarily out of service.
I am not sure why my set caught on fire. After I put the fire out I got ticked off and pitched it. I wish I still had it. It's almost like I am jinxed as far as tv's are concerned. That set burned up. My next one is the one I have been talking about in my other thread.I can not get the picture to work correctly. So I grabbed a different set and the flyback is dead. I can get one, but In my years of working on tube radios I have never had problem after problem. It seems like I am not destined to own a running tube tv.But, it is my mission, and with the help of people in this forum I will make it happen. Doug
Old 12-12-2007, 02:16 AM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
I think my luck is reversed.. I made the tv in my avatar sing.. Now ive taken on a radio project. a Delco R1128 and i am literaly scratchin my head over it.
Not to mention someone was in it before me and they left stuff hangin and i cant make heads or tails of it.. This is what they left me....
But thats another thread
Steve
Old 12-12-2007, 04:47 AM
Originally Posted by radio nut View Post
I made a typo on that , it should be 5ABP1. Sorry, will that work?
I should have at least done an Internet search before I asked about it. I found out the 5ABP1 is an oscilloscope CRT, and I cannot use it, but thank you for checking. What I am really looking for is a 5AXP4 or maybe an 8XP4, a small test-size CRT to use with chasses removed from their cabinets.
Old 12-12-2007, 08:18 AM
Steve McVoy's Avatar
5AXP4s and 8XP4s come up on Ebay all the time for almost nothing.
Old 12-12-2007, 08:39 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
TVs take a bit more time and patience to restore than a typical five tube radio. When I did my Motorola, I took it one section at a time. First the low voltage power supply. After all, nothing else will work without it. Next, the high voltage section and sweep circuits. This way, I could at least get a raster. Often times the set will work at this point but the signal circuits still have to be recapped. Restoring a TV is like eating an elephant, you gotta do it one bite at a time.
Old 12-12-2007, 10:31 AM
radio nut's Avatar
prices
All of the20,21,+23 inch tubes I have listed are $40.00 plus shipping.If your'e still interested , Contact Fair Radio.com. The 8BP4 I personally own I would like $30. for(that is what I paid).
Old 12-12-2007, 03:48 PM
Thanks, Steve. I put them in a saved search.
Old 12-12-2007, 11:55 PM
radio nut's Avatar
This 5ABP1 has tv picture tube written on the label (Sylvania I think)
Old 12-13-2007, 12:06 AM
radio nut's Avatar
Originally Posted by ohohyodafarted View Post
I'm interested in the 10 and 12 inch roundies 10bp4, 10fp4, 12lp4, 12kp4 if they have any.
They do have some used 10+12 inch tubes. I will start testing them friday. The bad thing about some of there stock are the part numbers. The majority of thier stock is military surplus. They have 10 inch dumont tubes they have 3,5,7,8, inch tubes all the way up to 20 inch(just a guess, I did not measure it) or so round pic.tubes, but they have military part numbers.I have to sort through these to find the hidden gems that we can use.Doug
Old 12-18-2007, 07:57 PM
Mike Stamper Mike Stamper is offline
AK Member
I need a good used 12lp4. Are any available?
Old 12-19-2007, 11:10 AM
Findm-Keepm's Avatar
Followin' the Rules...
The bad thing about some of there stock are the part numbers. The majority of thier stock is military surplus. Doug
I've got access to some Military logistics data (all strictly Unclassified) and decided to pull the data for "P4" and "P22" phosphor CRTs. Attached are two PDFs with the raw logistics data. They are text searchable. Hope it helps!
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
