Yep. That's one solid little set. Careful, the CRT will start to mark after a couple of hours if you leave it on the weather channel... lesson learned. Mine didn't have a severe burn but the ticker area was a teeny bit darker than the rest, it faded after normal use
I had one. I gave it away to a guy in my dorm because I didn't have enough room for it... I feel bad. It had a moderate red push and the geometry wasn't quite perfect, not objectionable, but noticeable. Wish I had kept it.
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
