Old 09-25-2007, 10:32 PM
In my house; we have two '94 13" Sharp TV's, a mid '80's Sony 19" TV, a 13" '86 KTV with rotary tuner, and a '76 19" Zenith Chromacolor II with rotary tuner. All of these are in working order and I plan to use them as long as they can be repaired. When analog TV gets cut off; I'll obtain some converter boxes and go right on. I collect old radio's and TV's as a hobby and, for the most part, find the older products superior to the new junk. I'm currently trying to restore a 25" '74 Zenith space command color console TV. The chassis (25EC58) in that monster is made of steel with a great deal of point-to-point wiring (similar to the old tube type sets). What circuit boards are used are actually small plug in modules that plug in the top of the main chassis. There is actually not much wrong with the set (just need to find the time to get back on it). OTOH, the newer imported garbage is built on a cheap printed circuit board with cheap "under rated" parts, and, often poor soldering. In many cases, these newer sets are not meant for repair. If they die under warranty, you may be able to get it replaced or repaired through the manufacturer. If the warranty expires, forget it! I've heard several horror stories about people purchasing expensive ($1K+) TV's just to find out that parts are not available when the set dies after a year or two. Many of the older sets are easier to find parts for because the components used in the older sets are more generic in nature. The newer sets use more speciallized parts that are designed for a particular chassis. It goes without saying that I'm not one to buy the most modern TV because of it's "looks" or because the industry says it's the "latest" technology. I'm sure my older sets will still be going when the majority of LCD, DLP, Plasma, or "whatever" is in the dump.
