Originally Posted by radiotvnut
I think that fifth parameter is called "F mode". Change that from 0 to 1 and you can advance to the other parameters. Make sure you set "F mode" back to 0 before you exit the service menu.
Thank you. I saw that param and did change the value but I did not hit any other keys. Once you set it to 1, do you operate up/down key to access those other parameters? Or do you operate the menu button again?
No,I do not have a CRT tester.
