Old 05-09-2023, 10:55 PM
pearsonk pearsonk is offline
6300 ohm resistor
Anyone have a 630ts, or clone of, parts chassis? I need the large 4", 6300 ohm
resistor found in the HV cage.
PM me.
thanks
pearsonk
Old 05-10-2023, 12:51 PM
Unless someone has one used to offer, the part is pretty much unobtainium.
You may try to make one via 3 power resistors 50w 5.3k +500 + 500, but the 5.3k in large sizes seem to be hard to find, closest I have found so far, is 5.6k, this may be close enough in this case.
HSA505K6J
THS50500RJ
Old 05-10-2023, 03:30 PM
Better yet use an adjustable one like this: https://www.mouser.com/ProductDetail...x9RYYOLg%3D%3D
Old 05-10-2023, 06:53 PM
Thanks for the tips. Hoping someone has a parts chassis I could get
one from. They were used in many sets mfg in late '40s......
Old 05-10-2023, 08:28 PM
Yes, they were, and are a high failure rate part. I think I've had to replace that resistor in every 40s Admiral chassis I've worked on.
Old 05-10-2023, 09:07 PM
what has me confused is, when I look at the RCA 630ts specs for the part, it says 20w, but when I look it up for my FADA it says 50w, did they just improve on the weakness of the 20w part?
and that's perhaps why my resistors have held up?
Old 05-10-2023, 10:09 PM
Yep, I have noticed several brands used 50w, others 20w....
A workaround is always possible...
Old 05-10-2023, 10:46 PM
mrjukebox160 mrjukebox160 is offline
https://www.elliottelectronicsupply....-rw35v632.html
Old 05-10-2023, 10:59 PM
Nice find. The original does have a couple taps though. I believe for adjusting width or linearity.
Old 05-10-2023, 11:00 PM
Originally Posted by mrjukebox160 View Post
this one is incorrect
because it needs to have taps at 5.3k &500 &500 but the over all resistance is 6300.
http://suzaku.live-evil.org/lin-adj.jpg
Old 05-10-2023, 11:01 PM
u beat me too it!
Old 05-10-2023, 11:21 PM
Thanks to MRjukebox160.
Perfect replacement as I need the full 6300..............
Mallory #RW35v632
Old 05-11-2023, 07:51 AM
IMHO, it would be unwise to use a fixed value for that resistor, as you would lose the ability to adjust horizontal linearity, for example, my FADA 895 has it tied to one of the center taps.
Old 05-11-2023, 01:08 PM
I didn't realise it had taps.
Old 05-11-2023, 03:05 PM
Here's a bad original. I believe it's that green corrosion that kills them.
