Old 11-22-2008, 02:02 PM
DENNYDOG's Avatar
DENNYDOG DENNYDOG is offline
PIONEER Lover :)
I think something like this would be fun to build with my nephew.
Old 11-22-2008, 02:26 PM
Brian Brian is offline
AK Member
I actually got interested in them again for a fantasy project. I've been into old tme radio shows for a couple of years and even went so far as to buy a Hallicrafters SW500 tube SW radio to listen to them on a local AM station that boradcasts Monday through Thursday nights. Went with the Hallicrafters so I could listen through a set of magnetic headphones. I'm plannng on building a low powered tube AM transmitter and broadcast the shows through it an pick them up on the crystal radio. Yes, I absolutey am looking to go back to my childhood and hear them as close to original as I can get and that's a long way from listening to them through my laptop.
Old 11-22-2008, 02:28 PM
onepixel's Avatar
onepixel onepixel is offline
I built one when I was a kid. It was fun and very gratifying to build something that actually worked!
Old 11-24-2008, 09:30 PM
nitrous's Avatar
nitrous nitrous is offline
Registered+Licensed User
Crystal radios
When I was a kid, I would tape record broadcasts from my crystal radio. The recordings were stellar, as they would be "crystal clear" (ie, free of any static or interference.) I was amazed by the sound of these taped recordings. Quite amazing.
gas anyone?
Old 11-25-2008, 12:28 AM
toxcrusadr's Avatar
toxcrusadr toxcrusadr is offline
I built one also as a kid. I remember it had a green clear plastic case. I corkscrewed all the wires by winding them around a pencil. It looked real nice.
I built a foxhole radio a couple years back and couldn't get it to work. Never did figure out why.
Summer's here and the time is right.
Old 11-25-2008, 11:31 PM
Philcofan42's Avatar
Philcofan42 Philcofan42 is offline
AK Member
Did you use a blue razor blade? The foxhole radio is tricky. Mine worked great when I finished it, but now it doesn't seem to want to. I might try swapping out the razor blade and see if that won't get it going again. You can still find blued razor blades (the one I used is for cutting carpet), but you can also take a normal blade, scuff it up and let it rust a little. You can also heat the blade to blue it yourself.
Old 11-26-2008, 06:04 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Is it possible to build a crystal set out of a dead transistor radio? i mean, using a the tuning capacitor, a germanium diode, maybe one of the miniaturized ferrite core coils and so on?
Also, is a high impedance 1920s moving iron cone speaker suitable for a crystal radio?
