Old 11-05-2010, 02:14 PM
19" Packard-Bell "Astronaut" B&W w/ missing yoke
Here's a neat looking 19" Packard-Bell "Astronaut" metal cabinet B&W portable that I brought back from SC. It is a tube set that uses a hand wired power transformer driven chassis and it looks to be from the mid '60's. Unfortunately, the deflection yoke is missing and I can't find any model or chassis number to look up a replacement. If someone has a yoke or knows what yoke this set uses, I'd appreciate the help. Also, the CRT was almost dead; but, it came up a little when I rejuvenated it. I suspect a CRT for this set would be much easier to find than the CRT for that '72 Sharp color TV.
Old 02-19-2011, 11:56 PM
While cleaning out, I found this TV and looked at it some more.
Does anyone have Sams 845-1, even if you don't want to sell it? I need to know the part numbers for the various deflection yokes that will work in this set. Once I have that information, maybe I can track down a yoke. Once I get the set working, I can then track down a 19DQP4 CRT.
Old 02-20-2011, 12:07 AM
Packard-Bell part #29797 (-1B)
Merit MDF-118 & M47-110
Stancor DY-27A
Thordarson Y-93
Triad Y-60-1
I have a spare Photofact, I can mail it to you if you want.
Old 02-20-2011, 01:12 AM
Thanks for the information and I'd like that spare photofact. I'll PM you my address.
Old 02-20-2011, 02:10 AM
ctc17 ctc17 is offline
They must have made the astronaut for several years, I have a really old one that uses a 5u4.
How did the crt check? I cant imagine where the yoke would have gone. It will probably need little more than that. They use very good caps.
Old 02-20-2011, 09:57 AM
The CRT is almost dead; but, I hope I can find a good tube once I get the rest of the TV going. Normally, I would not be going to such effort on a '60's 19" B&W; but, this set is an interesting looking set and it's not like Packard-Bell TV's turn up everyday.
Old 02-20-2011, 12:43 PM
kx250rider's Avatar
REAL TVs have TUBES!
I've seen a lot of those in the Los Angeles area, since they were made in West LA. It's an RCA licensing lab circuit, so there is a good chance that an RCA yoke might work. Being a tube set, there's a little bit of wiggling room as far as the impedance of the windings. Just be sure it's for a 110-degree tube, and uses a similar tube lineup.
Charles
Old 02-20-2011, 01:11 PM
Interesting point on the RCA licensing. All of the color PBs we acquired have parts that are interchangeable with the ctc17 style chassis. They are basically RCA clones with a few minor mods to the circuits.
Old 02-21-2011, 04:59 PM
I pulled the chassis just to look inside and it looks like this set was built in late '66. The chassis is fairly clean inside. I suspect that the CRT failed in this set and they used the yoke to fix another TV.
