Old 01-04-2006, 11:35 AM
Tinitus's Avatar
Tinitus Tinitus is offline
Forum Lurker
My Chromacolor II died
This is my bedroom set bought new in '79 or '80. It's a 19" table model with Space Command. Never been serviced. The other day my wife was watching it, said it made a loud crack or pop and the picture went white. Now it's a lit screen with a zig-zag white line.
I'm no technician and am reluctant to plunck down a alot of money to get it checked out. Does this look like an easy fix or is the tube shot? I guess this model gets a lot of respect from you TV guys, as I did some forum searches. I spend a lot of time on the vintage stereo forums, but am glad we have a TV section!
These numbers are on the set:
19KC52
SK1989W
Main: SX1010 * PL-12D * CD Player 3 * CT-F700 * CS-99A + Goodmans Magisters
Computer: JVC R-X500 * Stanton 8004 * TB Santa Cruz * Roland MA-110 + Genesis 1 + JVC PSW1000 sub
Occasional: Kenwood KR-4400 * Infinity 4000A
Old 01-04-2006, 12:05 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Originally Posted by Tinitus
This is my bedroom set bought new in '79 or '80. It's a 19" table model with Space Command. Does this look like an easy fix or is the tube shot?
The picture tube seems to be OK. High voltage unit also OK. The failure seems to be in the video amplifying unit. Perhaps a shot capacitor. For estimating the actual situation I need more information.
Can you adjust brightness and contrast?
Can you dim the picture with brightness control?
If a tv station is tuned, can you hear sound?
Old 01-04-2006, 12:24 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
If there is sound its in the video module, if no sound the problem is most likely in the IF or gulp.....tuner.
A member here (jstout66 ?? ) has lots of chromacolor II boards. A PM with a board number may help you out. I would pull off the back and see if there is any obvious signs of electronic destruction (exploded cap, burn marks, etc..) and go from there.
Jordan
Old 01-04-2006, 12:46 PM
If you turn the color all the way up, do you see any color on the screen? It's possible that the CRT arced and took out something on the video output board.
Old 01-04-2006, 01:06 PM
kx250rider's Avatar
REAL TVs have TUBES!
I seem to remember an exploding electrolytic on the 9-88 luminance module in those... Take a look. As Andy says, see if you have any color, looks like a photograph negative with the color all the way up (Chromatic switch OFF). If you do, that makes it unlikely a picture tube problem. That set looks like the later type with the inline tube, so it could also be on the CRT socket module. The proper way would be to troubleshoot, as you are probably missing a voltage to the CRT. That would eliminate the guesswork. Even if you take it to a shop, they shouldn't charge much. Expect to pay a $25 bench fee to have it checked, and maybe $60 more or so to get it fixed unless it is the tube, or a tough troubleshoot.
Charles
Old 01-04-2006, 01:51 PM
Tinitus's Avatar
Forum Lurker
Thanks for the quick replies!
When first turned on, the screen turns shades of pink and green for a second or two, then settles into silver with the zig-zag lines. These are static when the cable box is off, they flicker back and forth when the box is on or tuned to an over-the-air station.
None of the controls affect the picture-tint, color level, black level-screen stays colorless.
There IS sound.
I just took the back off to inspect. No visible damage, all 7 or 8 modules look OK, no exploded components or burn marks.
Old 01-04-2006, 03:57 PM
yagosaga's Avatar
VK Member
Does brightness control have an effect? Can you turn the brightness to dark or not?
Does somebody here has the schematics (as a pdf file)?
Old 01-04-2006, 01:55 PM
jpdylon's Avatar
Sounds like the video output board (not luminance) this controls the information to the guns. Perhaps the Y signal is missing?
I haven't had this problem with any chromacolors I've worked on....
Jordan
Old 01-04-2006, 02:12 PM
Tinitus's Avatar
Forum Lurker
jpdylon, which board would that be? They don't have names, only numbers. I found the 9-88 module, no damage.
Old 01-04-2006, 02:34 PM
jpdylon's Avatar
Off the top of my head, i do not remember which board number. I have some service info for chromacolor IIs but I'm not sure if the board numbers are the same.
I'll have a look this evening. It would be the board that has the three yellow leads going to the picture tube. each yellow wire has a color representing the color of the gun its going to.
Jordan
Old 01-04-2006, 02:37 PM
jstout66 jstout66 is offline
I do have boards, so hollar if it is indeed a bad one, along with the module number needed.
Old 01-04-2006, 04:11 PM
Tinitus's Avatar
Forum Lurker
There is no "brightness" controll, per se. Turning every knob on the control panel has no effect on the picture.
Gotta go to work now. We'll resume later.
Bob
Old 01-04-2006, 06:38 PM
from looking at the set, I think it may be one of the last Chroma 2's as it looks like the one with the inline tube. Zenith only made those for about a year. Off the top of my head I can't figure out which module it would be either. Once someone has the schematic let me know what board to look for. I don't think it would be the board that plugs into the picture tube from the symptoms given, but could be wrong.
Old 01-04-2006, 08:33 PM
Chad Hauris's Avatar
What about the resistor pack on the video module that says "Caution--HOT". It seems like the later chromacolor II's used these and they seem to be a problem on slightly later models.
Chad Hauris
Old 01-04-2006, 08:50 PM
jpdylon's Avatar
That's the board I ment......
9-89 on most models, not sure about yours.
Jordan
