Old 10-16-2012, 11:37 PM
jmm83 jmm83 is offline
Panasonic ag 1970 Problem
Hi I have a Panasonic AG 1970
Problem is that i took the board out of the vcr & unhooked the some of the wires to put some new caps on the board & now when i turn on the vcr it will not load a tape & the head spins.
I have a working ag 1970 & i looked at where the wires go & everything seems to be right. so now i dont know what to do
Old 10-17-2012, 02:12 AM
waltchan waltchan is offline
Sounds like some wires were inserted in the wrong place. Re-check again...
Old 10-17-2012, 06:39 PM
tried that & still the same thing
wires are in the right place
Old 10-19-2012, 03:04 AM
today i tried unhooking the wires from a junk AG1970 with bad head & same problem happend i dont know why they do that there must be something you have to do reprogram or reset it somehow.
i will never unhook the wires from my good one or any panasonic vcr ever again
& does anyone have the service manual for this vcr
Old 10-19-2012, 03:59 PM
You can try using this ask-a-tech VCR page and describe your problem for each VCR problem you have, and he will reply back to you in a timely manner.
Go to studiosoundelectronics.com, and click the ask-a-tech link at the left side (third).
It's possible that the regulator in power supply failed, causing video head to spin with no tape inside. You probably have to trash it. Remember, Panasonic is PanaScam sometimes, due to its cheap-looking construction and cheap materials Panasonic used.
