Old 12-08-2010, 01:01 AM
miniman82's Avatar
First Light: 1952-2011
Space Command @ estate sale
Not affiliated
http://www.estatesales.net/estate-sales/146802.aspx
Evolution...
Old 12-08-2010, 02:09 AM
GeorgeJetson's Avatar
GeorgeJetson GeorgeJetson is offline
Why does it have two remotes?
The one on the left looks newer
I like the one with the oval buttons on the right
No wonder this circuit failed,it says "made in Japan"!
Old 12-08-2010, 02:18 AM
The one on the left is actually one of the oldest SC remotes and probably correct for this set.
I noticed the CRT has a cataract, you don't see that much on B&W tubes.
Old 12-08-2010, 08:10 AM
...I noticed the CRT has a cataract, you don't see that much on B&W tubes.
Looks more like the phosphor's almost completely blown away, ie., the neck was snapped off allowing violent inrush of air. Usually the inrush is slower, causing a smaller "hole" near the center of the screen. Bill(oc)
Old 12-08-2010, 09:16 AM
Thanks for the info Eric!
I had no idea,I was just going by looks,the one on the right is much sleeker and I love the oval buttons.
Thats a neat ad with George Burns,thanks for sharing it!
Old 12-08-2010, 10:01 AM
That is a cataract on that tube, some B/W tubes in Zenith's are bonded. I have two with cataracts but they're on parts chassis' so I'm not too worried about it.
Old 12-08-2010, 12:05 PM
pallophotophone pallophotophone is offline
I hate to be the bearer of bad news, but that tube is broken- that set has an external glass.
Wish I had a nickel for every one of those I put a new CRT into over the years.
Old 12-08-2010, 01:12 PM
That set has the 21CXP4 tube that has different characteristics than the more common CRT's of that era. I was thinking that the yoke might be damaged as well. That neck really took a big hit. Wouldn't doubt it was a " curb setter" and the yoke was a victim of the " copper scrounger".
Old 12-08-2010, 04:08 PM
After taking a closer look I'd say you're right, the tube is broken.
You can see the Aluminizing through the screen.
Bummer, it'd probably be hard to find a new one.
Old 12-08-2010, 04:20 PM
RobtWB's Avatar
RobtWB RobtWB is offline
nice looking old Zenith, very similar to the ~1963 model I have excepting mine is not a SC set
bummer about the crt - hopefully someone can go and at least go snatch those remotes before they end up in a dumpster
nice looking old Zenith console record player/stereo there also as well as other good looking items
Old 12-08-2010, 04:40 PM
Ampico-kid's Avatar
Ampico-kid Ampico-kid is offline
Yes....and if someone does grab the remotes...I'd be happy to buy the one like the remote in George Burns hand. I have this same Zenith SC 400, and don't have the correct remote for it. I've been looking and have never come across one..........Bob
Old 12-08-2010, 11:38 PM
I have one of these but with a boring cabinet. I had been wondering about the correct remote. The one I've kept with it looks older, but I don't know which model it really goes with. That crt might not be the toughest to find. Could be one of those that crosses to the fairly common 21CBP4.
Old 12-09-2010, 10:49 AM
If you look at tube characteristics you'll find that tube is one of the few that uses only 50 volts on G2. You probably could re-work the circuit to accomodate the higher voltage on the substitute tube. Why zenith did it, I don't know.
Old 12-10-2010, 02:05 AM
Tubejunke's Avatar
I would love to have that to stuff the chassis in my Zenith with a GREAT 24" tube. The chassis is probably about the same AND I would have a remote. I am not going to tell my Zenith story again, but I will say that I still haven't ever got it working OR found a good home for it. Seems like nobody wants a TV when you are trying to make some room. Perhaps it is meant to stay in my collection! My cabinet is more upright like most 50's sets with beautiful dark wood. I NEED to get it going if I can find the time and the problem.
