Old 05-19-2012, 11:38 AM
lnx64's Avatar
lnx64 lnx64 is offline
Mis-aligned color
The color on my TV is not aligned very well. For example, it's not centered ontop of the luma signal good. See the mario bro's coin symbol at the top.
http://img.photobucket.com/albums/v3...ragon/tv-1.jpg
Once again, no POTs to adjust this.
Is this going to be caps again? Ugh, I just fixed the flyback, I don't need to be tinkering with this chassis, I just want to enjoy it.
Old 05-19-2012, 12:22 PM
ctc17 ctc17 is offline
Red smear = weak crt lots of the time
Old 05-19-2012, 12:44 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Did it look like this before you replaced the flyback?
Perhaps maybe the yoke assy. is loose? Could also be that the convergence rings may have been disturbed. Usually there sealed with some type of glue/paint.
"IPC 610 Class E & J STD-001 Certified"
Old 05-19-2012, 12:51 PM
RobtWB's Avatar
RobtWB RobtWB is offline
Given the age of the set ... weak crt
Old 05-19-2012, 12:54 PM
lnx64's Avatar
Can't be weak CRT and it did this before flyback. On a greyscale image no problems at all.
Old 05-19-2012, 01:02 PM
mrflex65's Avatar
Is your game console on top of tv? Yeah, i know i'm reaching....
Old 05-19-2012, 01:46 PM
RobtWB's Avatar
Always a crap shoot diagnosing from a screen still but sure looks like a weak crt and static converg appears off as well. Of course as others have posted could be other probs.
Old 05-19-2012, 03:31 PM
I see all color smeared - blue into green as well as red into blue. I don't trust the game console. Does it look this bad on a better source like a DVD or cable? Have you tried to see if it changes with fine tuning?
Old 05-19-2012, 03:55 PM
lnx64's Avatar
Happens on all sources. I tried fine tuning and while it helps a little doesn't fix it all the way. If for example I hook the tv up to the Lima output of my DVD player for a pure monochrome image there is no color bleed. This leads me to believe the CRT is fine. I'll try and get a cross hatch pattern tonight for convergence.
Old 05-19-2012, 04:27 PM
Hmmm- delay line problem, or misalignment somehow?
Old 05-19-2012, 04:38 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
Could be an IF alignment issue. did you try channel 4?
Old 05-19-2012, 05:19 PM
lnx64's Avatar
Yes tried 3 and 4. Happens on all VHF cable channels too
Old 05-19-2012, 07:47 PM
The smear from a weak crt never shows up on the greyscale only on colors smeared to the right and red is always the worst.
Old 05-19-2012, 08:19 PM
lnx64's Avatar
Really? I thought they did. On my hitachi on a greyscale screen at high contrast it bleeds.
Old 05-19-2012, 08:42 PM
RobtWB's Avatar
if you find it is a weak crt, sometimes but not always, you can set for a b/w pix and adjust the color and tint slowly forward and get a nice picture ... a case in point
in front of me is a '96 production RCA 36" set with a weak crt ... with the remote and the aux controls i adjusted the set slowly advancing the color to ~ 75% and keeping the tint weighted heavily towards green ... now have an excellent picture
how long will it last? a roll of the dice it is ... could be 15 min ... 15 days ... 15 years
mine has lasted several months with no sign of degradation
