Old 01-19-2018, 12:22 PM
WISCOJIM WISCOJIM is offline
Cataract repairs - are we missing the safety glass aspect?
I've seen plenty of threads where people "fix" a cataract, and I have also done many myself in the past. But I always had this feeling that the way we are sealing these jugs is all wrong.
Does anyone really believe that taping or caulking really makes the CRT front "safety glass"? If you think sealing only the edges of the now cataract free CRT gives you any real protection, you are fooling yourself. Why do you think that inner layer was put in there for in the first place? No, not just to keep dust out...
Real safety glass requires that the inner layer holds the front and back glass together, just like in automotive windshields. Removing that layer just gives you two pieces of glass with an air gap.
Has anyone tried doing it the correct way using a resin between the CRT and the "cover glass"? If so, please share details.
I think we all should reconsider how we remove cataracts, and come up with a way to put the "safety" factor back in.
Old 01-19-2018, 12:46 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I'm all for it....if there's a way.
Old 01-19-2018, 01:08 PM
ohohyodafarted's Avatar
Bob Galanter
You are correct. Little protection is given by taping the safety glass to the crt.
That said, as hobbyists, we do not have the materials or equipment to do this kind of rework.
Even at Hawkeye, a fairly large crt rebuilder, the safety glass was fastened in place with a bead of silicone sealant and carton sealing tape around the circumference. If Hawkeye didn't have the resources to bond the safety glass, then I think it unreasonable to think we can do it.
ME http://AntiqueTvGuy.com
Old 01-19-2018, 01:04 PM
Tom9589 Tom9589 is offline
I fully understand the principle behind automotive safety plate glass. Why did we go for so long with a separate safety glass with a huge air gap between the glass and the CRT? Also consider CRTs with no safety glass, just a band around the tube under tension. All you want is that the safety glass stop the CRT glass from being projected outward toward the viewer, not hold it in place like a windshield.
Old 01-19-2018, 01:54 PM
Don't mistake plate glass for actual safety glass. I know that a lot of the 1950's TVs I junked in the past did have actual safety glass (with the internal bonding agent) in front of the CRT. And that safety glass was between the CRT and the viewer.
I'm assuming in the case of those CRTs there were improvements in the glass to bring up the safety margin.
With the force of an implosion, a sheet of glass offers little actual protection to keep the front glass from shattering and sending its own shards everywhere.
I would imagine in every instance where a CRT was designed with the resin layer, it was there for a specific safety reason. Otherwise they would have come with just an edge bonding in the first place.
Old 01-20-2018, 12:54 AM
reeferman's Avatar
Life was simpler then.
[QUOTE=Tom9589;3195034]I fully understand the principle behind automotive safety plate glass. Why did we go for so long with a separate safety glass with a huge air gap between the glass and the CRT?
We had a 21FB set with come in with a BB hole in it that went through both the safety glass and the CRT face glass. Just left a hole the size of the BB. We couldn't believe it. A one in a million shot, kid.
BTW, there was no "huge air gap".
Old 01-20-2018, 02:17 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Must've been one hell of a bb gun. You sure the kid wasn't playing with his dad's .22?
Old 01-20-2018, 08:04 PM
reeferman's Avatar
It was a BB gun.
Old 01-20-2018, 07:53 AM
I assumed Tom was talking about those sets that have the CRT about 1-1/2 to 2 inches behind the flush mounted glass on many of the old TVs.
Old 01-19-2018, 02:00 PM
There were both glass scatter tests and specifications and impact tests/specs over the years, I don't think we can definitively say that the resin bonding was intended specifically to limit scattering, or only to meet the impact tests. If there is someone around who has access to the historical development of UL tests, or very unlikely, some manufacturer's documents (boy, would they not want that to be public), I think we can't say. The resin bond MAY have been mainly for dust exclusion, while the glass continued to provide the same protection as when it was air-spaced.
Can someone who has witnessed breaking a resin tube tell us if it captured all fragments like a windshield, or did glass pieces spray?
If the latter, then the resin may have reduced the force/distance of the spray, or may not. Actual test results with/without resin would be needed to answer this.
Old 01-19-2018, 02:56 PM
TUD1's Avatar
TUD1 TUD1 is offline
TheUniversalDave1
I've done several cataracts and I don't really worry about implosion all that much. I once did a cataract removal on the bathroom floor in my pajamas. A few months ago, I needed to bust up an old dead Zenith 25GP22, and even with a good sized sledgehammer, it took a lot of force to get it to pop.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan
Old 01-19-2018, 07:07 PM
madlabs madlabs is offline
Worry? No. Take sensible and reasonable precautions? Hell yes! I've never done a cataract removal but have popped a few CRT's in my youth (back in the early 7's we didn't know better!) and they can really throw some glass sometimes. A piece in the eye would really ruin your day. I'd be wearing a face shield, some gloves and a jacket. Maybe it goes back to my firefighter days, we did crazy stuff but with proper gear.
What about the air gap between a Predicta CRT and the plastic safety screen?
Old 01-19-2018, 07:25 PM
TUD1's Avatar
TheUniversalDave1
A piece of glass in an eye? Meh. I've got two of 'em.
Old 01-19-2018, 11:17 PM
MadMan's Avatar
The Resident Brony
I've said this before, just buy a shitload of UV-activated LOCA glue. It's the stuff they use to glue cell phone's glass to the screen. Kind of expensive for that much, but hey, that's the price of 'safety.'
Game is hard.
Also, while I agree that the mushy stuff between the CRT and the safety glass does definitely add some protection... I'm pretty sure that if the tube wanted to implode, anybody in the vicinity would have a really bad day, whether or not it had the mushy stuff.
Old 01-19-2018, 11:24 PM
And I'm sure it would have given more protection when the tubes were fresh, and not with 50+ year-old crusty mushy stuff like we see nowadays.
