Old 01-03-2017, 10:10 PM
josephdaniel's Avatar
Learning as I go
Question JVC HR-D470U Transport Issues
Hi all,
I have an old JVC HR-D470U side loading machine that seems to have some transport issues. The machine will load the tape as normal and the drum will spins up as normal. However, the machine will not advance the reels in the tape, and as such the player shuts off after about three seconds.
Side note: I can hear a squealing while the machine is trying to advance the tape.
I am guessing this is a relativley simple issue somewhere in the player, but having little experience with these machines I thought I would check and sww what you good folks have to say.
Lebe dein leben für dich selbst
**Searching for any all tube or hybrid or color portable sets would consider some early solid state color too**
Old 01-04-2017, 02:07 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Originally Posted by josephdaniel View Post
Hi all,
Loading belt on the bottom of the deck. Not real easy to replace on that chassis.
Old 01-04-2017, 03:05 PM
I've got one of those JVC long-ways-loaders...IIRC it's in parts deck status...I've got a working Zenith badged version so I've not gotten to it yet.
If my JVC is too much of a junker I may be open to letting it go.
Old 01-04-2017, 03:53 PM
Ed in Tx's Avatar
Here's a pic I found of the bottom of the deck. I have highlighted the load belt. Also I highlighted the Grounding screw for that board. That is important too. I used to put a small star washer under the screw to ensure the ground connection would never fail again. Tighten any others while in it. (Last thing I wanted when I did this for a living was re-do!)
Old 01-05-2017, 01:18 PM
Learning as I go
Oh geez. You wpuldnt happen to have a service manual for this deck would you? That belt really does look difficult to get to.
I would like to get this deck back up and running, as it had a fantastic picture quality before it was put away. However, it's been sitting on a shelf fpr quite some time I just hope it hasnt developed any more strange issues...
Old 01-05-2017, 02:15 PM
Old 01-06-2017, 09:12 PM
Learning as I go
Well, I hooked the deck up to a monitor this evening to see if I could use it as an RF modulator this evening, and was able to get a parts of a picture for a few second with lots of banding. However, it quickly turns to snow...
I'm guessing failed electrolytics somewhere. Its probably fixable, but at this point I'll probably just shelve it for now...
Old 01-07-2017, 09:39 AM
If you are getting video hum change the big lytics on the secondary side of the power trans on the PS board. My Zenith badged JVC had a lytic fail badly there...Picture was barely noticable behind the hum, audio was lousy with the HiFi cutting out regularly...I changed that cap (IIRC it was 2200-3300 at 16-35V) and it went from crap to a solid performer.
