Old 01-10-2015, 01:00 PM
Biscuithead Biscuithead is offline
Trade or sell... 1953 Sylvania 172k CRT and chassis
I am a stereo/turntable guy... I picked up the guts out of a 1953 Sylvania
172k console. The former owner turned the cabinet into a wet-bar. I am only interested in the mono turntable. Is there any value or interest in the CRT, the chassis and the mono tuner?
I paid $50 for it all, and I would be very happy to break even....
Colorado
Tell me how to test the filament in the CRT and I will...
Pictures below...
Found out that the CRT is a 21EP4b
1-15-15 : Pins 1 and 12 show continuity so the heater is intact at least...
CRT can/will be sold separate from chassis...
Old 01-10-2015, 01:05 PM
More research revealed that it might be a 1952
Old 01-10-2015, 03:01 PM
It is not just the filament (though if the filament is bad then the CRT is definitely bad).
CRT cathode emission is important, you need a CRT tester or someone that has one, and is willing to lend it to you, in order to confirm CRT condition.
Old 01-11-2015, 07:02 AM
I understand, I have had to hunt down a person with a CRT tester to prove out a couple of Oscilloscopes over the years...I was just taking the first step...
Old 01-11-2015, 08:51 AM
[CRT is a 21EP4B
Pics:
Old 01-11-2015, 08:53 AM
Wrong pics...
Here they are:
Old 01-12-2015, 06:14 AM
It looks like the CRT is a replacement from 1963.... from what I found online about the 21ep4b. I still can't find a pin diagram to tell me which is the filament...
Old 01-13-2015, 05:07 AM
If there really isn't any interest, I'm going dive in and cannibalize it soon...
Old 01-13-2015, 08:43 AM
Heater pins are 1 & 12. Each side of the locating key. The 21EP4 is a cylindrical faced CRT and rather uncommon. Stromberg-Carlson seemed to use them alot.
Old 01-15-2015, 05:56 AM
Thanks! I'll check it out and post my findings... I am thinking about diving into the chassis (mainly just for the Transformer-rectifier) ... Is there a great reason to keep the chassis and CRT together since they are not original to each other?
Old 01-15-2015, 09:44 AM
The CRT is a ten year newer replacement. I wouldn't want the original CRT. The one shown is a great replacement for a set that needs one. Most collector's understand that most sets that age, would have the CRT replaced by now, so original factory issue isn't important.
Unless someone needs the chassis, I wouldn't worry about it.
Old 01-15-2015, 05:34 PM
Right on...
I checked continuity between pin 1 and 12, and it rung out good... so that's intact at least...
Old 01-16-2015, 07:12 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Could you please post a pic of the chassis from the rear? I'm looking for the one I had in '66 (my very first TV), but later cannibalized. it had the dual 5U4 socket assy. mounted at a 45 degree angle atop the Power Transformer (but had a 3AG slo-blo fuse/holder in one of the socket holes...
Old 01-16-2015, 08:44 PM
That was the one piece that I wanted from this... Just the power supply tranny with the rectifiers on top... This is that chassis, but I would want that piece... any interest in the rest?
Old 01-19-2015, 12:16 PM
Einar72's Avatar
Possibly - What is your zip? Also, do you have any of the knobs? I actually found an NOS channel knob assembly, but the volume knob seems to be harder to find...
Thread Tools
Display Modes
