Some New Listings I Found
http://cgi.ebay.com/1982-RCA-COLORTR...#ht_790wt_1139
Local Pick-Up Only in Iowa, $35. Apparently only needs minor repairs. Picture looks decent. http://cgi.ebay.com/vintage-zenith-9...#ht_500wt_1154 Bicentennial Zenith. Pretty small (only 9"). Probably only needs a DTV converter box and it's ready to go. http://cgi.ebay.com/1975-ADMIRAL-SOL...ht_2734wt_1139 This is the first Solid State Admiral that I found on Ebay. (Has the EXACT manufactured date on the back---July 29, 1975). http://cgi.ebay.com/PHILCO-COLOR-TV-...2#ht_500wt_928 I know many of you are groaning over the price of this next set. It's very expensive. (No surprise it's from the same seller trying to get rid of his 1972 Zenith for $199). This one is in worse shape though. http://cgi.ebay.com/TV-TUNER-CABLE-B...8#ht_500wt_928 This isn't a TV set, but I thought you guys would be interested in this Teknika Cable Box. Although it's being sold by that one crazy seller from Villa Park, IL, it's actually only $12.99 and is compatible with any set that uses screw terminals or coax cables (which is pretty much every TV). (I believe the 300-ohm twin-lead connectors from the rabbit ears attach directly to the screws on the back of the cable box, but correct me if I'm wrong). Matt |
