Old 07-03-2016, 01:02 PM
Originally Posted by Findm-Keepm View Post
'Tis either an AN219A or AN229A - the non-A versions had the early logo. There was a later AN249/A, but I seem to recall those having a dark removable sunshield...differences in the 219/229 are only in the trim level - they all had the same innards.
Your open resistor is a dual, 3 ohms and 37 ohms. You'll notice the diode across the on-off switch - that provides the bypass for the instant-on feature. Cut the diode out if you want to kill the instant on. We did it all the time on those sets - a real CRT killer. BTW, the CRT is most likely either a 500JB4 or a 19VDGP4 (the worse of the two). That pigtail should be a 2-Ampere fuse.
Panasonic issued a bunch of mods for these sets - the 16" and 19" sets had vertical problems, mostly with the vertical output transformers opening. There was also a mod for fringe vertical hold issues, and changed the values of a couple of resistors in the vertical (300-series parts, IIRC).
What is the last two letters on the fly? DS=flammable type and PS=non-flammable type. Panasonic had a couple of these burn up flybacks and start a house fire in '71, so the "A" models had the new flys, and the non-A models had a "replace-at-next-service" replacement program for the flybacks. One of the vendors in the back of Radio Electronics apparently got the excess "DS" flybacks, and you could buy them for a buck each for a year or so. All the markings were removed, but a little sleuthing found out what they were.
Good sets, save for the junk CRT, and the CRT-killing instant-on....
Cheers,
The set in the picture looks to have the 19VDGP4 CRT.
I didn't think Panasonic products had all those problems.
Old 07-03-2016, 04:16 PM
Findm-Keepm's Avatar
Followin' the Rules...
Panasonic issued about 30-40 corrections, mods and service notes each month. As the librarian for my Dad's shop, I used to "juggle" the binders, shifting as the library grew. In one year, we added ten 2" binders, just in "white sheets" - TV mods and service notes (usually corrections to schematics or parts lists). They also issued pink or blue sheets for audio - but changed those to white as well, when they started to shift to microfiche. It seems blue and pink don't photograph well, making the shift to microfiche slow.
Panasonic had a run of bad CRTs - rumor was they bought cheap ones from Clinton or Hitachi and got bad batches. They fixed the problem quickly, as the whole Matsushita name was attached to their acquisition of Quasar. We dropped the warranty work after they started up Quasar - too few sets to mess with. We kept up the library until about 1983 or so. I still have all the microfiche, save the odd audiophile stuff I sold years ago on eBay for $$$.
IIRC, Matsushita settled on 16 warranty stations nationwide for Quasar, and sold 90% of the sets within those areas. Nearest to here was Arlington, VA - just outside of DC, and covered Baltimore as well...
Brian
USN RET (Avionics / Cal)
CET- Consumer Repair and Avionics ('88)
