Old 10-19-2012, 06:37 PM
StellarTV's Avatar
StellarTV StellarTV is offline
Now that you've put the RTV on the flyback this may be a moot point for this particular discussion, but what does the jury say about using the High Voltage Corona Dope that comes in the jar with the little brush? I've never tried it to completely recover a flyback, but it works great for insulating other sensitive points in the HV cage. Why not recoat a fly with that?
Old 10-19-2012, 08:33 PM
I've used dope to touch up a few hotspots on flybacks with good results. It might not work so well on the whole donut and over the remains of the old coating though. The RTV is very tough and flexible while the dope it hard and brittle.
Old 10-19-2012, 10:18 PM
Kevin Kuehn's Avatar
Workin' Late Again
Hmm. No, not really. The Predicta shaft is hollow and fits over a piece of metal protruding form the switch. These still might work though.
Figures with that concentric shaft setup. Mine aren't the exact same as the the ones I linked to earlier. Mine are possibly a 20 year old OEM part with a plastic shaft. Anyhoo...
Old 10-20-2012, 07:07 AM
Reece's Avatar
Reece Reece is offline
Did anyone ever use that tool handle insulating dip for covering a flyback or other parts? Should be able to brush it on.
Reece
Old 10-20-2012, 10:46 AM
Workin' Late Again
Not sure if it would have the required dielectric properties.
Old 10-20-2012, 02:43 PM
Reece's Avatar
Rather than tool dip, liquid tape might do it. Available in spray or brush on. They say:
"Liquid Tape has the strongest dielectric protection on the market; 1,200 v/mil, 5 – 7 mils per coat."
They recommend applying several coats.
Reece
Old 10-20-2012, 05:46 PM
DavidGoncalv's Avatar
DavidGoncalv DavidGoncalv is offline
Bob, did you see this on the Early TV website?
I have a number of the Push-Push Off-On switches for Predicta televisions. These are new old stock and are $19.99 plus $5.20 Priority Mail. I take Pay Pal. Don, dpatterson002 at comcast dot net. (1/18/12)
Old 10-20-2012, 06:16 PM
Yes, that's where I got my switch
Old 10-21-2012, 02:05 PM
I've been working on the screen this weekend. There were some gouges in the plastic but wet sanding has mostly gotten them out.
A bit more buffing and I'll call it done.
The CRT sure was dirty
Old 10-21-2012, 02:51 PM
Wow, is it supposed to be that yellow-green?
Old 10-21-2012, 03:08 PM
Yes, it is. The later models like the Princess used a different kind of plastic that is clearer, harder and doesn't stink.
Old 10-21-2012, 08:40 PM
Down Under's Avatar
Down Under Down Under is offline
I KNOW that stink! I brought it all the way over to Australia!
A mixture of well worn athlete's runners, parmesan cheese, BO and goat vomit!
Fantastic job on the polishing, hope mine comes out like that when the time comes. Does the stink become less when you clean it? I've heard that it does. Looking at the cloth you used to clean the face of the tube, I wonder how many brighteners may have been fitted over the years that needn't have?
Four Predictas down, now to score a Continental.
Old 10-21-2012, 09:31 PM
n2bew's Avatar
n2bew n2bew is offline
My Call is now K2BEW
Looks great, curious what you used to wet sand it with? ie. grit and what you wet it with, just water? I have a GE portable with a plastic screen that has gouges I need to sand out too.
Old 10-21-2012, 10:57 PM
Yes, the stink is reduced with a good cleaning, but it's does creep back - especially on warm, humid days. Yes, it was quite dirty and I'm hoping it wil be noticeably brighter once back together.
Thanks. 320, 600, 1000, 1500 then Novus #3 and #2. Yes, I just used water.
Old 10-21-2012, 11:59 PM
Workin' Late Again
Bob, I didn't realize that apparently the on-off switch on my new Philco set had at some point in the past been changed to a push-pull type, so I made the false assumption that your switch was the same type. The switch I posted the link to is a push-pull. Didn't realize yours had a push-push until I watched your last video.
