Old 07-28-2009, 04:47 PM
Alaric Alaric is offline
My TV is a 48" RPTV , but it uses 3 CRT guns. Does that count?
Lee
Marantz-PM7200 , SA8260 , ST6000
Paradigm-Studio 60v.3
Music Hall-mmf-5SE
Bellari-VP-129
Old 07-28-2009, 11:41 PM
AUdubon5425's Avatar
2005 Durabrand 27" in den, 1977 or 78 13" RCA XL-100 in bedroom. Working on a Durabrand replacement ('74 XL-100 console)
Old 02-04-2010, 05:28 AM
Dude111 Dude111 is offline
Analogue is Awesome
I still have a CRT tv and i love it!!
I have a CRT monitor also,much better picture
Im my opinion CRT WAS ALWAYS A BETTER ANIMAL FOR GOOD PICTURE..
Old 02-04-2010, 10:17 AM
peverett peverett is offline
I still have only CRT based TVs. The production dates for these range from 1950 to 2004. The local Wal-Mart still sells one CRT based model(supprising).
I do have an LCD computer monitor that has ran fine for 6 years, so do not have any qualms about buying a LCD based TV in the future.
Old 02-04-2010, 10:50 AM
Zenith26kc20's Avatar
34 inch Sony CRT high definition (adopted and repaired)
25 inch Sharp (old) works great! (given to me when owner bought his first LCD)
3 inch JVC with converter box in kitchen (bought new in 1976)
These are the daily drivers. There are around 40 others, most work, some waiting for attention.
Zenith roundie in Mississippi on a converter box.
25 inch Emerson (Funai) LCD with a dead tuner on a converter box (adopted also)
And a Haier (LG) 42 inch plasma in the guest bedroom. My girlfriend hates it so it stays tucked away..... (also adopted, replaced the x main module and it works)
Old 02-04-2010, 01:33 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Currently, my regular duty color watcher is a mid-80's Curtis Mathes 19" set. I also watch my 50's Philco Diamond D 21" a lot.
As mentioned before, it's too easy to pick up a good CRT set on Craigslist... their a dime a dozen these days. I also find it interesting that there are sooo many HDTV's on CL. Apparently, lots of folks are hanging sets on the wall nowadays because of the abundance of wooden "entertainment center" cabinets listed as well.
While I'm sure I will eventually get something more up to date, it's simply not high-priority for me right now.
Charlie Trahan
Old 02-04-2010, 02:43 PM
Freebe HDTV 32" phillips, one bad cap in the power supply section (22uf 50v) was keeping it from turning on.
Dont have anything but CRT tv's, they seem fine to me, and there is something unnatural about the flat screens tv's at least seems that way to me.
Old 02-04-2010, 02:48 PM
And if you're going HD, there's nothing better than a CRT IMO. I am in love with my Sony KV-30HS420
How is the picture on your Phillips in HD? Have you hooked it up to it or are you using a standard signal?
Old 02-04-2010, 02:51 PM
I use the over the air antenna (rabbit ears) and its great!
Old 02-04-2010, 02:52 PM
My daily watcher is a ten-year-old RCA CTC185 XL-100 19" table model, but I also have a Zenith Sentry 2 (same screen size) in my bedroom. The RCA set has given me excellent service over the last decade -- no problems whatsoever except for the antenna port snapping off the tuner PC board (twice) when the set was about a year old.
Other than that, however, that set has been excellent. Very sharp, clear picture on cable, DVD and VHS (even more so now that all TV is digital, and yes, the difference is noticeable on an analog set, at least to me). Say what you will about RCA's initial barrage of problems with the on-board tuners in the CTC18x series chassis, but once those problems are resolved (by resoldering the grounds around the tuner and reinforcing the mounting of the antenna connector, as was done on my set the second time the port snapped off), the TV will operate flawlessly for years to come. Mine still has the original CRT; no matter. Still makes almost as good a picture as it did when it was new--in fact, the picture may even be better since the tuner issues were resolved, as I have a sneaking suspicion that the RF port may not have been soldered properly to the tuner board when the set was made.
My Zenith Sentry 2 19" table model has almost 15 years on it, but still works amazingly well. It only had four years of actual use, from 1995 to 1999, then I moved and bought the RCA CTC-185. The Zenith is now used only as a backup and to cross-check when my cable service goes out.
Old 02-04-2010, 02:57 PM
oh and I forgot, lunch time leave it to beaver is on the Emerson 1965 B&W set, Rockford and Hitchcock Presents is on the 1964 Maggie astrosonic, and as soon as I get one of my color sets put back together I will be watching Rockford on that (the CTC17, Zenith,CTC16 or the Sylvania, prob rotate them thru, but they will be regular at least for a couple hours each week).
My guess is I am going to really like that Zenith for its nice stereo amp.
My B&W Maggie astro sound GREAT, I love the quality sound with the big consoles.
Old 02-04-2010, 03:25 PM
truetone36's Avatar
electronics packrat
My living room set is over 20 years old and shows no signs of giving up the ghost yet. I use a '72 Zenith in the mancave almost daily as well as a '56 Olympic B/W set.
Old 02-04-2010, 06:25 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
I do, I have a 1982 Zenith System 3 in the living room, a 1984 Commodore 1702 monitor in the computer room and a 1998 Zenith 19 incher in my bedroom along with a few spare sets.
Old 02-05-2010, 04:09 PM
stromberg67's Avatar
stromberg67 stromberg67 is offline
Question
Don't remember if I posted to this before (old age ain't for sissies hahaha), but the family daily watcher is a 36 inch Trinitron won in a raffle about 8 years ago.
After it bites the dust, I'll buy a flat screen for the Mrs., and I'll watch that, and the vintage sets, more often the oldies, I think. The little Sylvania 15 inch portable, 1970 vintage, that was a dumpster rescue has a super-nice picture, and I sit close lol. REAL deep, dark greens, not yellowish. Good for sports.
Kevin
Old 02-05-2010, 04:24 PM
Yep, all my TVs are CRT. The main one is a 27" Trinitron from around 2000. I do have 3 LCD computer monitors though. It was nice to reclaim some desktop real estate
