a great B&W. Turn the color all the way down & concentrate on the B&W. BTW the pix of the set on its side looks good. Purity is way off but thats normal on its side. Looks to have good B&W and color. Maybe a complete " by the book" CRT set up is in order before anything else. Zeno |
I have a really good B&W picture and it don’t turn to ghosting moving the fine tune it gets snowy. With the IF out there is probably no way I could set up the color I have a dot bar generator it shows dots and line pattern and shows color bars the colors in the bars seem to be off a bit but clearly shows each color it does show all from the bar dot generator on screen. At this point I didn’t try to set the color up. I would think the color has to use the IF ???
This is just one of the pictures posted that I have seen with color in it, I'm very sure that color is working with direct video input.
Sent from my VS501 using Tapatalk
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために |
| Audiokarma |
Should I be able to set up the color with the IF the way it is ???
correct, the purity is very bad, and Tron is a bad choice for a color example, but there IS color, weak as it is, red on the lips, and blue on the glowy but of the suit.
the set IS working enough to do a quick purity and convergence on it. It's still highly suggested to build the video amp, and rig for A/V input until a future time that you have to tools to do the IF alignment.
you have the RCA pattern generator, does it not work?
http://www.videokarma.org/attachment...7&d=1648416460 and it's pretty certain that you can't align the IF visually, 95% chance of making it worse each time you try.
Was able to set up the color and purity convergence made sure hv was 24kv this pick is a dvd test point B and degauss
| Audiokarma |
Don’t really understand why this works when the IF is messed up is it because I have B&W video already
Test pattern generators RF output isn't always consistent with a normal RF modulator used for watching videos. That test pattern generator probably has a composite video output. I would try hooking the composite video output of the test pattern generator to the composite video input of whatever RF modulator you use to feed program material to your sets (if the composite video output of the generator is variable level use a different known working TV fed by your RF modulator to set generator video level). Then I'd feed the output of your RF modulator into the TV and see if I could optimize color through the TVs tuner by playing with fine-tuning and color level...If you can get a color test pattern from your generator through the RF modulator you use for DVDs and TV watching, through the Motorola's tuner and looking good on screen then you should be able to get color from a normal TV program on screen.... Whether alignment is good enough to pass good monochrome and or sound at the same time remains to be seen... One reason I don't like gated rainbow generators like that is that while they give you a good color pattern that's all they can do while displaying color. That Philips pattern I mentioned shows you color response and accuracy, monochrome response, gives a good method of checking sweep linearity, and several other things...When you potentially have multiple issues in a picture and they may all be interrelated to varying degrees that pattern is a helps making adjustments that are the metaphorical walking and chewing bubble gum/rubbing your head scratching your belly...It let's you see clearly how all the picture systems that could be having issues are doing all at the same time while your messing with things.
Live video is very different from a still static non moving image.
As others have mentioned, when you fine tune the set, if you get color shifting especially in the reds, it's a sign that the IF is out of alignment, and it is not unusual for it to be able to lock with a test pattern and not a live video.
UNLESS its the camera the live pix is TOO DAMN BRITE !!!
The set is still on its side also. If it is in reality when you get it back on its feet you will need to re do the set up. You should be able to turn the color, brite & contrast down & extinguish the raster or nearly so. These sets were NOT brite ! In the day most watched them in a darkend room with curtains drawn. This is NOT a Chromacolor, Trinitron, EFL or FTM CRT that you could light a room with. If you overdue the brite everything starts to fall apart pix wise As for generators we did 90% of our set ups were by eye. Live shows worked better for us & give a real world look at the pix. Try it. No confusing mirror, just lay across the set, look at pix & reach back to adj. SO much easier. Also generators can add problems if the TV's controls are not set right. One last thing. Put up a pix of the set with NO signal, just snow. Snow can tell you a lot believe it or not. 73 Zeno
And the reason the set is on it's side is that it has the access panel removed on the bottom to reach the underside easily for service with the chassis still installed. It's prob petty much understood that once the set is upright and in it's final location, a final purity and convergence will need to be done again, as is always with these sets.
| Audiokarma |
