#106
well.... I worked in my Uncle's shop when I was a kid, from the years 1977 thru late 81, and I'm thinking he was doing those recalls in 1979-1980. I don't know how far back Zenith covered. I think I read somewhere that all set makers had problems with high-voltage and deflection on early solid state models, especially the ones that used a tripler and a flyback. Zenith didn't change it's chassis very much during their runs. I think the first Chromacolor was from 1968 or 9 thru 1972. Chromacolor 2 was from 1972 or 3 thru 1980 with the System 3 chassis coming out in 1978. during that overlap Chroma 2's were reduced in price and considered a "lower" end model with the System 3 being quite pricey. I ran my 1976 Chromacolr 2 I got Saturday for 24 hours. I have a minor connection problem I'll have to figure out. It has a slight vertical flicker, but when you rap on the right side of the set (where the controls are) it goes away. It's only done it twice in it's 24 hour run, so I'll probably take the back off and make sure ALL modules are tight. The picture of course is outstanding!!!
#107
I have one of those System 3 Space command models like Doug showed a picture of earlier...mine only has 2 UHF tabs, U1 and U2...so I can only set up 2 UHF channels.
I guess the previous owners did not watch much UHF. I would like to figure out how to fool the set into thinking a UHF tab is in there so I can get more channels. Usually I feed all the TV's in the house from the VCR and a cable amplifier but I actually use the tuner on this system 3 set as it has a remote control. |
#108
If it's the UHF tabs that have a hole, you can probably just leave the VHF tabs out to change it to UHF.
#109
I think I have one or two of those repair kits in the bottom of a box somewhere. I bet that was something to see (or mostly hear) when one of those caps went, especially if the crt went with it. Seems like that would be enough to scare away some customers for life.
Bryan |
#110
Let me expand on this a little...
The fact that the retrace (safety) caps on the Zenith sets caused runaway hv, and sometimes even killed the CRT, Is not a problem unique to CHroma 2's(by the way, those are probably the BEST tv EVER made, with a crt(the delta types) that seemed to last forever, with a picture that would rival, even beat a MODERN SONY).The simple fact is, ANY solid state set can have this runaway High voltage problem, even a modern one. BUT, since'74, most set have had a HEW-inspired "hold down" circuit, to prevent catastrophic failures like this.
Here is what happens: in ANY set(including some of our favorites, like the RCA ctc169) there is a capacitor in the horizontal circuit called the "retrace" or sometimes,"tuning" capacitor. it is usually somethuing like .0162/1600v., or so, but it is ALWAYS a "pf range" cap. this cap helps to "tune" the flybacks operation to the horizontal ckt. if this cap opens, the tuning of the ckt. is upset, and the high voltage can go VERY high(40kv or higher!!) But, the hold down ckt. samples the HV, and if it sees excessive HV, it will shut down the HV/set, at ONCE!! the old chromacolors (and other brands) did NOT have this feature, the idea was the cap would fail, and physically come apart. This opened the ckt. to the horizontal out, as the B+ path ran through the cap, as a safety feature, killing the horizontal voltage , and protecting the set. BUT, too often the cap did NOT physically come apart, and then, the HV would go sky high, kill the flyback, tripler, and sometimes, even the CRT. I do not think I have replaced one of those caps since'87,when I was 19, and the last one i did, it DID physically come apart, sparing the set. I replaced it with an "ORANGE DROP", the color of the new one, and it was fixed ,IIRC. |
| Audiokarma |
#111
Please explain how the runaway HV kills the CRT?
#112
bgadow, I would think it would!!!!!! I can still remember those customers we had where the cap exploded and it took the tube. They were OLD, and I had a mental image of them in their rockers when that thing went, and them being so startled that they knocked those LAZY-BOYS over and couldn't get up......
#113
The HV arcs through the glass to the yoke windings...there is apparently enough heat generated then to start melting the glass and the neck of the CRT cracks off.
Now, I wonder why there is that much excessive reserve capacity of the circuit to generate HV over 50 KV...in a tube type set, even if the plate cap of the regulator tube comes off, the HV will not go that high. |
#114
COOL!
That sounds like fun.
I've got a 36" RCA that I garbage picked. I think the CRT is bad (tension on the shadow mask), but it still kinda functions. I've got a huge backyard. I'm thinking, set up this type of fault, connect it with a LONG extension cord, power up with the remote...Happy 4th of July!!!
#115
Its been rought the past few weeks, estate sales were not too good, and I was moving into a new home. Just went to a few estates again today and found a nice little 1973 Admiral 12" portable color set, hybrid of course. Nice low hour set. Works nice too. Thankfully, the original owner put a swich on the power cord to shut the set off (instant on) which saved its life, as the picture is still bright yet. I think im the first to take the back off, all orignal tubes and all the tubes were still caulked to the sockets.
| Audiokarma |
#116
Something strange about this set, I got the date of this set from the 3.58 crystal, which normally always have a date code. The original admiral crt however is stamped "77-13". The tubes are dated N77-13 as well? Is there any way a tube set like this can be from 1977? I always thought the portacolor was the only tube set at that time?
Another strange note, on the lower right corner of the speaker grill says "K SOLID STATE 880" It looks original, as the tag is a greenish blue like the speaker grille. What exactly do they mean by this? Its a hybrid set? The only total solid state is the IF and TUNER? Im thinking that if this set could be from 1977, and since it had instant on, the "solid state" was a marketing thing to sell it, since it would turn on as quick as a solid state set? You would assume not many people would be interested in a non solid state set in 77, so that had to put it on there to sell the thing? Just a thought.
I tolerate the present by living in the past... To see drh4683's photo page, click here To see drh4683's youtube page, click here Last edited by drh4683; 07-17-2004 at 05:13 PM. |
#117
Well, my Philco roundie hybrid has a "SS" on the front. I would assume that to mean solid state, but mine is like yours... only about 9 transistors, and all the rest are tubes.
Nice looking set btw! Really clean!
Charlie Trahan He who dies with the most toys still dies. |
#118
Loopholes
Well they say SS, not 100% SS don't they?
Any set that has a CRT can only be about 99.0% SS anyway.
#119
Here's a couple of things you might check-- does the label / company identifier on the back (or on the picture tube) make any reference to Rockwell International? Rockwell bought Admiral in 1974. Also, don't forget to take a look at the inside of the back cover or other plastic parts and see if there was a date code mark inset in the mould. Could it be that the date code on the pix tube is actually 71-13 or 72-13, but just marked badly..? Dunno what to say about the crystal though. Oh, and I'm sure you knew this, but that "SS K" logo is the old K-Mart (S. |
#120
Here's a couple of things you might check-- does the label / company identifier on the back (or on the picture tube) make any reference to Rockwell International? Rockwell bought Admiral in 1974. Also, don't forget to take a look at the inside of the back cover or other plastic parts and see if there was a date code mark inset in the mould. Could it be that the date code on the pix tube is actually 71-13 or 72-13, but just marked badly..? Dunno what to say about the crystal though. Oh, and I'm sure you knew this, but that "SS K" mark is the old K-Mart (S.S. Kresge stores) logo; Admiral used to make specially-marked TV sets for K-Mart. |
| Audiokarma |
