#91
As you can see some rust where mice peed on the CTC12B chassis but only destroyed the damper tube socket, the filament keeps going out. All 4 PC boards were spared the This looks very promising as long as there are no gremlins like the other two chassis. The 12's HV is robust at 25 kV (dark screen) and adjusts easily and so is audio. I can’t get a picture unless I reduce then advance the contrast control and see a momentary flash of a raster. The service switch gave me a fuzzy but solid line that I could verify R-G-B screen controls operated. I pull out my handy “Pomona” CRT adaptor so I could easily measure crt gun voltages, and they looked within 10% of schematic K=335v, G1=190v, G2=615v It was then, right at bedtime that I noticed a little black wire was missing from the 4.7meg 2w resistor in the HV cage to the CRT socket for the focus anode. It must have been pulled out of the CRT socket, leaving the pin when I initially got the set and immediately cleaned it out 5 years ago. The CRT socket has two rivets so I can access to solder on some Belden wire rated for 20 kV that of similar size and black insulation like original. I can replace the wire to 6DQ5 cap as well. If this works out, I will do all the electrolytics, they being even older than me
"When resistors increase in value, they're worthless" -Dave G |
#92
#93
John |
#94
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために |
#95
The contrast control was open, allowing the 12BY7 cathode to rise to 40 volts DC, cutting it off. Part #112840 I could easily order another from Moyer's, but found a 368 ohm with same shaft in my "stash" that even had the tap when the original did not. Ill end up placing an order for something before this is over. Now I have a raster, can get chroma lock with hum bar and poor vertical sync. The next step is a full recap, CTC12 chassis has a similar problem to the other two and I just need to bite the bullet and recap. I was also working on this set Saturday night during the Zoom with ETF with my video on. Steve, Mr. Mike and everyone else made it the most interesting thing "on" that night!
| Audiokarma |
#96
But I **did** forget that the 15 was the lone departure of a long line or RCA color TVs that didn't use some sort of tube focus rectifier. ![]() We used to carry at least six 2AV2s on the truck all the time, but I can't recall changing more than a small handful of the SS rectifier in the 15 series. John |
#97
The heater voltage for the 2av2 is, 1.8v +/- 0.27v and the spec clearly states “ under no circumstances should heater voltage be less than 1.53v or more than 2.07v And yes, where the may be almost the same tubes, the heater voltages make them unsuitable to be interchangeable, or at least I would never do so, thus the reason I mentioned it.
#98
I jumpered out the resistor and installed a 2AV2. Problem solved. |
#99
However, it's been proven that the SS substitute for the HV rectifier will not work, and overheat and burn up, it happened to me, and to shango066 ( as seen in one of his videos ) on a CTC-16. Not sure why it smokes, but it seems only the good old glass type works.
#100
John |
| Audiokarma |
#101
When we changed my dad's original sulfide CRT in his CTC11 with a HiLite rare earth tube, it would eat up 3A3s every couple of months (blooming). We put in an EDI 3A3 and lasted a day and failed. We returned it for exchange and the replacement lasted another 5-6 years or so until the replacement picture tube got weak and it was retired for a '77 XL100. I cannot say with any degree of certainty that I used on in a CTC16 specifically though. John Last edited by JohnCT; 12-23-2020 at 01:38 PM. |
#102
Always like the idea of less flyback load
, also glad not to be using the SS version of a 3A3, yet that filament load could have a measurable effect on 6JE6 cathode current. Very Good point. Its not enough that I use the 128v High Line tap on the power transformer when we run 121-124 v here thanks to a new pole transformer - not an option on CTC11 and older chassis tho.
#103
Both shango066 and I tried the NTE508 / SK3756 version and they both fried, mine in 90 seconds, his in about an hour, who knows, perhaps a real EDI 3A3 sub would have worked, but they be hard to find.
#104
This does however bring up a question that I have tossing with for a while, should the FBT in my 16LX ever fail beyond repair, I do have a replacement for it, but it's not a FBT for an XL, but an NOS one for a CTC-16, which is vertically identical, save for the heater windings/ voltages, since I have a SS focus tube, that won't matter, it will be unhooked, but the HV rect, add a 2.4 ohm res and use a 3A3? Or hook direct and keep using a 3CA3?
Of course, this is all moot, if the FBT in there now never dies!
#105
That makes me wonder if the ECG and SKs weren't sourced from the same company not named EDI. Other than the one bad SS EDI in my dad's TV, I sold a few dozen (not a big sample I agree) and can't remember any problems. I also sold a few dampers as I recall with no callbacks. I may still have one somewhere in storage. If I run across it, I'll take a pic of it or you can have it for experimentation. In retrospect though, I wonder how a shorted SS rectifier would affect the fly. If a 3A3 goes bad, they only go inert. Maybe a SS rectifier isn't a great idea. John |
| Audiokarma |
