Old 02-10-2017, 07:30 PM
TUD1 TUD1 is offline
Just got through doing the RCA Colorama with the Zenith style halo. I used a heat gun, and about an hour and a half of my time. I had to force the wooden pieces in between the glass, and amazingly, nothing broke. I got the glass off just fine, with LOTS of heat. And yes, the green stuff smells like burning piss. I'll take the RCA style any day over the Zenith style.
Old 02-10-2017, 07:50 PM
Originally Posted by edison64 View Post
But as I stated the green cataracts can only be removed with a heat gun and lots of patience or a hot wire usually a guitar string hooked to an old battery charger you simply pull it through and it melts its way and boy does it stink
No need to run current through the guitar string or heat it....I've done cold guitar string zenith cat removals, and they work as well as hot does. Interesting that the heat gun method works, but I would still not recommend it due to the implosion hazards involved in the heat gun methods uneven heat...I've had RCA CRT faces crack from being unevenly heated by the sun so I'm a bit less of a fan of heat based cat removal methods than some.
I've always thought it smells exactly like a brand new out of the box inflatable pool toy....Magnified by like 30X.
Old 02-10-2017, 07:59 PM
WISCOJIM WISCOJIM is offline
Happy memories of my youth! Every time I get a whiff of that smell it reminds me of when we went to the Sinclair station to gas up Mom's car in the 1960's. They used to give away inflatable Dinos with a fill-up.
Old 02-10-2017, 08:48 PM
What did you say about implosion? I took care of that prior...
Old 02-12-2017, 02:40 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
I did a quick of a 20x20X.1 volume of 40cubed inch, about 22 oz. Not sure if its sold in bulk for that kind of delivery.
Huh. A fair point. 22oz = 660ish mL. It's sold in 5mL usually, 50mL would be about $30... but really, I still think it's feasible, the layer would just be very thin. But then... with no real gap, that diminishes the safety aspect, doesn't it?
idk
