#91
As to the color in the convergence pattern with color turned on: that's normal.
Its caused by beating between the color subcarrier and the sharp lines that occur at random phase with respect to it. There was a "prefilter" thread here recently that puts a bandpas filter on luma in an s-video signal before mixing luma and chroma. That would eliminate it. |
#92
BTW the IF board on the Zenith is a 150-170, if anyone has one lying around and is willing to sell please feel free to PM me. There is also one speaker I would need, its the one in front of the convergence board : 49D1194. Mine is completely destroyed (got to wonder how that happened :/ ) Thanks! Last edited by Dreamsbeard; 05-24-2015 at 08:17 AM. |
#93
Has some of you may know, I am in the process of getting some parts to get the set going. (thread here for the ones interested : http://videokarma.org/showthread.php?t=268243)
But since I want to get most informations kept into one thread , i'd rather ask technicals questions here , so here goes : Could anyone tell me if a 2 watt speaker would be a suitable replacement for the one that is busted? I know 8 ohms will do , but I have no clue as what is the minimum W the speaker needs. thanks! |
#95
Should be. I have three old TV speakers sitting here and the really teeny one says 1 watt, a slightly bigger one from a scrap 19" Korean set says 1.5w max. 3W, and the biggest one, pulled from a Sony, says 2W.
| Audiokarma |
#96
Most sets with smaller speakers (cones under 7") only run into the 1-5W range.
Odds are that unless you like your tv LOUD, you'll probably be running that speaker well within it's ratings. It'll distort bad to warn you that your pushing it at high volume anyways... I've got a couple of 7W (really closer to 12W but heath rated them rather conservatively) Heathkit A-7E mono blocks that can shake the room/be heard through out the house when run at full tilt (feeding speakers rated to more than handle the amp's power)....Odds are 2W will be above sufficient.
#97
Yeah, most are 1, 2 or 3 watts, but I just don,t know if it makes that much of a difference. I suppose I could get around that by not putting the sound at maximum on my set... I just wanted to be sure.
#98
