Old 06-16-2012, 06:34 PM
boy iv been thinking about that since i started this episode ,if anyone got any ideas short of cutting it out of the layered venir and slicing it thin and re-gluing it to the new panel , shoot me some ideas this problem will come up again when restoring a nicer and rare tv .im still thinking about it
Old 06-16-2012, 09:59 PM
Magnavox300's Avatar
..better in black & white
Originally Posted by snelson903 View Post
going to add extra support to the top ,been exp. with re-doing old legs
Those legs look beautiful!!
Keep it up!!
Old 06-16-2012, 10:11 PM
Before you get too technical on it I recommend Taking a good hi res photo or cutting close to it and putting it in a Xerox machine so you have a good copy to fall back on if the original gets ruined.
Old 06-17-2012, 11:23 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Taking a photo is probably your option... then print it. You could play with the options in your photo/print/scan devices and try to make it "not look like a photograph" before you print out your final result to put inside the cabinet.
Charlie Trahan
Old 06-17-2012, 04:08 PM
finished sanding the legs one set off the rca and other the zenith ,i quess i wait then clear coat last thing
Old 06-17-2012, 04:31 PM
side panels removed and cleaned frame
Old 06-17-2012, 04:42 PM
kvflyer kvflyer is offline
You keep this up and you will have people coming to your house for cabinet work. Nice Job!
Old 06-17-2012, 04:47 PM
removed the tv orginal panel schematic transfer to photocopy, also found a factory repair on the production line ,iv noticed the upper right mighter joint didnt match the left now after removing side panel i see why,just loosen it it moved it over and re-glued it , i found that i had a sam's photofact allready in a lot i bought off ebay for this model so that worked out
Old 06-17-2012, 05:04 PM
i dont know if im liking cabnet work ,i think i rather weld it instead.
Old 06-17-2012, 05:18 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
That would be an interesting show....
Old 06-17-2012, 07:58 PM
If those leg caps are aluminum, they would shine up like mirrors with fine steel wool and water on the lathe...
Old 06-17-2012, 08:39 PM
we can shine the legs for the rca on another show , im tired . when i restore the rca ill call it [ this old rca ] ha ha
Old 06-17-2012, 11:18 PM
Great job! it's nice to see someone getting these old Zenith sets going, no matter the condition. It looks AWESOME so far. I can't wait to see the finished set, with a bright color picture.
Old 06-18-2012, 12:40 PM
added the extra supports before i put on the panels there all glued & screwd ,i will need sand the glue joints where the panel will be placed . i will paint the inside the orginal color when finished.
Old 06-18-2012, 12:48 PM
i dont know if you got my pm so try to email me again thanks
